Beautiful planking Tobias
Interesting decision about the choice for the inner planking treenails.Hello everyone, it is done.
The starboard side is planked, now about 2000 nails will follow, which I will make from walnut pins. I have tried 3 variants and I like the walnut variant quite well. The other two were dark wood spatulas and the other was dyed toothpicks. All three variations are relatively the same but more work.
See you around, greetings Tobias.
Hello Uwe, sorry that I'm only answering now.Interesting decision about the choice for the inner planking treenails.
Did you made some samples for the decision? Maybe you can show us a photo with the comparison.
Before you start check where the nails will be later covered by interior walls, decks etc. - maybe you can reduce the total number by some hundred nails
personally I would do the nailing with dark walnut wood but without stucco, remaining firm that you must likeHello Uwe, sorry that I'm only answering now.
The first picture shows the three materials used:
Wood putty walnut,
walnut square 1mm x 1mm and dyed toothpick (walnut)
In the second picture from left to right
Wood putty - walnut - toothpick
you're 100% correct about the chestnut.@Steef66 cool idea with the spines of the shell I think it is chestnut, I know walnut shells only smooth, but of course I don't know how many varieties there are.
Hi Tony, we have a top wood supplier here that I can order almost all dimensions from, Donnie mentioned him in one of his first posts from LeR, here is the link again.you're 100% correct about the chestnut.
Thank you Paul for your interest. The plan is to make a few samples with different woods to be able to compare in the future.Hi Tobias, I appreciate your careful/thoughtful approach here. It seems like you will be making a larger sample board and I would heartily support that. Even on my much more modest Vasa I made several sample boards, but then hurried the experiments and ended up making a horrible mistake that I had to repair costing me nearly two months of progress. I learned that taking the time to make larger sample boards is not wasted time - especially for something that will be so visually important. I truly admire your work my friend!
Ok yes I just looked at it. I’m not clear.. they can supply dimensions small enough for treenails ?Hi Tony, we have a top wood supplier here that I can order almost all dimensions from, Donnie mentioned him in one of his first posts from LeR, here is the link again.
Shipping is worldwide and you can also order special sizes.
Willkommen bei der MassivHolzWerkstatt.
Betriebsferien vom 22.12.2023 - 7.01.2024. Alle Bestellungen die in dieser Zeit gemacht werden verzögern sich.modellbau-holz.jimdo.com
?alder
