POF La Palme (L'Amarante) Corvette 1744 1:36 (Ancre Monograph) by Tobias
The bolts with the heads are looking extremely good - which tool did you use to prepare the washer?
I guess first the inside hole and afterwards the outside ring.....
just my subjective taste:
the "nailing" of the hatch cover is maybe a little bit too much (what I mean are too much nails for this small cover) - it is looking like a french nailed gunport-lid - is it wooden nails or metal? which diameter?
Thank you very much for your interest.
I would like to answer or explain a couple of questions.
Hallo Tobias, a very nice and clean solution you have found, looks very elegant, even if later you do not see that it exists, but you know it, that's the point. Saubere Sache das. First Place Metal
Adi yes you are partly right that you can't see it later, but I would like to always remove three frames to see better the inside, i.e. open it.
Witaj
Jestem ciekawy w jaki sposób i czym robiłeś podkładki. Piękna praca pozdrawiam Mirek
Hello
I'm curious how and what you made the pads. Beautiful work, greetings Mirek
Mirek and Uwe I bought punches from Amazon with which I drive the discs out of the brass sheet. First I punch the sheet metal lightly, then I drill the hole and then I punch it out completely.
Here is the link to Amazon
So now to the hatch Uwe, yes, it almost looks like a gunport, but it is correct, there are two layers of boards offset by 90 degrees, with the lower layer of boards being smaller to fit into the chamfer. The nails are made of wood and are 0.4 mm thick.
I hope I was able to answer all questions and thoughts.
Dziękuję za działanie.
Po prostu lub oryginalne kilka pytań.
Adi tak, po części masz rację, że później tego nie widać, ale zawsze poprawiłbym trzy ramki, żeby lepiej zobaczyć wnętrze, czyli otwarcie.
Mirek i Uwe Kupiłem wykrojniki z Amazona, oprócz wybijam krążki z blachy mosiężnej. Najpierw lekko dziurkuję blachę, następnie wiercę średnicę, a następnie wybijam go całkowicie.
Oto link do Amazona
Więc teraz do włazu Uwe, tak, wygląda to prawie jak port strzelniczy, ale do prawdy, są dwie warstwy desek przesunięte o 90 stopni, przy czym dolna różnica desek jest mniejsza, aby podziała do fazy. Gwoździe wykonane są z drewna i mają grubość 0,4 mm.
[ZAŁĄCZ=pełne]365894[/ZAŁĄCZ]
[ZAŁĄCZ=pełne]365895[/ZAŁĄCZ]
Mam nadzieję, że udało mi się uzyskać na wszystkie pytania i przemyślenia.W
Dziękuję bardzo za zainteresowanie.
Chciałbym odpowiedzieć lub wyjaśnić kilka pytań.
Adi tak, po części masz rację, że później tego nie widać, ale zawsze wolałbym usunąć trzy ramki, żeby lepiej zobaczyć wnętrze, czyli otworzyć.
Mirek i Uwe Kupiłem wykrojniki z Amazona, którymi wybijam krążki z blachy mosiężnej. Najpierw lekko dziurkuję blachę, następnie wiercę otwór, a następnie wybijam go całkowicie.
Oto link do Amazona
Więc teraz do włazu Uwe, tak, wygląda to prawie jak port strzelniczy, ale to prawda, są dwie warstwy desek przesunięte o 90 stopni, przy czym dolna warstwa desek jest mniejsza, aby pasowała do fazy. Gwoździe wykonane są z drewna i mają grubość 0,4 mm.
Mam nadzieję, że udało mi się odpowiedzieć na wszystkie pytania i przemyślenia.
Witaj
Dzięki ciekawy sposób. Pozdrawiam Mirek
