POF La Palme (L'Amarante) Corvette 1744 1:36 (Ancre Monograph) by Tobias
frame by frame -> step by step
Mühsam ernährt sich das Eichhörnchen
your frames are looking very good
and also your bolts with square heads - 0,8 are looking accurate for the thickness of yopur frames
How are you do them?
Hello Uwe, I found a square brass wire, but only 0.6mm and
0.8mm according to the translation I should make 0.4mm.
Translation: The spacing of the bolts is irregular, as is the length of the overlap of the elements. Although we can use 0.40 brass wire perfectly to simulate the studs, we will use them in 0.4 x 0.4mm
Usual dimension given in some contemporary documentations are telling us the diameter of the bolt (which is taking over the forces), but not of the head of the bolt, which is much bigger than the bolt
Hello, everyone. Here I would like to introduce you to my second project, I am trying to build the La Palme, a sister ship of the L' Amarante. I hope that I get a lot of input from you to identify any errors and to fix them. Le Coureur will continue to be built whenever I need a change. Now here are the first attempts in the POF.
Hallo Tobias
Alles Alles Gute zu deinem Geburtstag - lass es dir gut gehen
Hallo Tobias.
First of all Happy Birthday Birthday-Cake
I have read you build log and will follow with great interest.
Good to hear you are enjoying the new pup. We lost our Berner Sennen Wilson last year at the age of 5 due to an auto -immune disease and now enjoy our very happy and lively Labradoodle Guus who will turn 1 end of this month.
Herman
