Great work Tobias.Is that Twelve Apostles in the background of one of your pictures?
Kind Regards
Nigel
			Kind Regards
Nigel
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Kind Regards
Nigel
Nigel which picture do you mean
Hi Nigel, I'm trying whether it will work is still in the stars but I think so because my ambition drives me.Thanks Tobias,I was way off, but it was out of focus
Very nice model, and can't believe you are into building your first framed model already.
Kind Regards
Nigel
Hallo Tobias,Hello folks, well in the last 1 1/2 weeks I couldn't do anything because a gastrointestinal flu completely logged me out. Here you can see my attempt to build the first frames, well it is more difficult than it looks because I had to realize that the frames tend to warp when gluing and the double frames then no longer fit exactly on top of each other. Let's see how I can improve this technique of gluing. Maybe someone has a tip. Today I will first rebuild the upper part of the shipyard (waterline no. 9). Have a nice sunny weekend everyone, spring is just around the corner.
Se you
I experienced the same problem with my build - the slightest change in angle where futtocks meet will throw the whole frame out of whack. If I had enough money, I would have built frames Harold Hahn way - devours wood, but you'll get as close to a "perfect" frame.Hello Uwe, thank you very much for your information, very helpful. Yes, you see that relatively correctly, but the problem is not with the glass plate. If you look at my picture again you will see that I put it between two glass plates as you describe. I localized two mistakes:
My first mistake is more in my head, i.e. a mistake in thinking, because when sanding the glued pair of braces, I only have to concentrate on one side of the glued paper because they are "the same".
The second and also the crucial mistake is more because it is very difficult to sand down the cut as you cut it (paper template). The difference to the kit is that you have to copy your individual frames from the mono and then make the individual separating cuts. If it is missing here by one or two tenths, then you have 1-2 mm on each side at the top (distortion).
Conclusion: Work much more precisely, use much better glue -> Don't use a glue stick, but the one recommended by Oliver, your additional tip: put weights on the glass plate and the time factor in peace and patience. Yes, in the end it is all a learning process and your great support.
For glue of paper against wood I have very good experience with Marabu - FixoGum
This rubber cement is fixing the paper - you can cut your frame elements out and afterwards you can easily peal the paper and glue away - no sanding is necessary to get rid of the paper
You will love it and never use anything else
Uwe and Adi that's exactly the glue, Fixo Gum I've been using since Saturday and I'm also very satisfied.Hallo Tobias, I absolutely agree with Uwe, I use the same technique and am very satisfied.
