POF L'Amarante Corvette de 12 canons 1744 1:36 (Ancre Monograph- Gérard Delacroix) By Shota
Hello Shota, there can be breakage from time to time, the important thing is not to give up. Paul is absolutely right, you can avoid a lot of breakage if you work with the grain of the wood, you can also avoid warping in the wood if you glue it.
Something like this:
The importance of the grain direction was already mentioned - it is important, otherwise the frames could easily brake.
The old shipwrights made it in the same way
photos from the Museum in Hamburg
You will need slightly more wooden sheets, but it is worth to do so.
Another point will be also, that you, when you finished the hull structure, that the appearance of the wood surface will look better
Hi Shota,
sometimes it is helpful to fake a bigger part by glueing two smaller parts together to get a good grain direction. The picture shows the floor timber which I build from to parts.
What an interesting project You started. I will follow this log.
Dear Shota. Let us just say you have explored and found the boundaries of this type of wood .
Although I pay attention to the grain of the wood, occasionally a piece of wood is broken bending it too extreme or too fast.
View attachment 410417 View attachment 410418
I agree with Paul and Tobias. I learned this to by experience. It breaks when in the wrong direction to easily. But love the 'rozen' carf knife of you. Good thing to do a lot by hand. That gives always a good result.
my dear friends
thank you very much for your help and explanations for the method of work and for your kind words :)
Now I have questions for Tobias and anyone who knows/can help
1. How to create the apparent slope in the current halves of the frames
(I am attaching a picture with the drawing and what I built, as well as the area with a black line that I am having difficulty with)
When I was looking at Tobias and Giampy65's build, I'm not sure I noticed that little bend
The next subject in which I have difficulty understanding the way of working and reaching the required result is in regards to the way of creating the connection of the split frames connecting to the Transom beam and the Wind transom.
In the first attempt I made the connection areas of the two parts straight and without bending/angle and when I tried to glue the frames to the Wind transom there was a gap of about 1.8 mm. After re-examination I understand that I am required to make the connection areas inclined at a small angle/bending, But I don't know what the right and appropriate
method
The first two pictures are from the first attempt and the next one is from the second attempt before sanding and gluing as well as marking the bending areas at an angle
thanks in advance for your help and guidance
Hi Shota, well the parts are a bit tricky and it took me about 3 or 4 tries and it's still not 100% correct. It is also extremely difficult to explain and I hope there are no translation errors.
About frame 52:
It's a bit tricky but in the end not that difficult. I first made the two individual pieces and adjusted the recess piece by piece.
About the extended timbers:
You first cut out the basic shape and then glue on all four sides shown in the plan, then file or mill out the small bevel. In the next step, you can make the actual mould.
Hello my dear friends
After a week of thorough and patient work, I was able to repair the stern area.
I must thank Tobias and Giampy65's for the most helpful guidance and assistance.
I actually recreated most of the parts: frames 52 and 53, the Transom beam and the Wind transom and the top part from the ebony tree.
I am satisfied with the intermediate result which will allow me to reach the final precisions for all the stern parts and the hull of the ship later on in the construction.
I would like to point out that the dimensions of the frames from the right side to the corresponding edge on the left are the same as the drawing with an accuracy level of tenths of a millimeter, resulting in final accuracy later in the construction.
For now I will let you see the photos of the process and the result
20231129_184807.jpg20231202_162915.jpg20231202_164252.jpg20231202_164355.jpg20231209_155204.jpg20231209_155255.jpg20231209_155332.jpg20231209_155425.jpg20231209_155554.jpg20231209_155816.jpg
