Thanks Nigel, yes if it is of some interest to you of course I will post the progression of my model on this board !
Marc that would be fantastic,I am sure everyone will be interested.
Kind Regards
Nigel
I think what Michel did is not correct.
Are the deck beams still loose, after the ledge glue-up? How do you prevent the glue not wicking into the beam mortises?
Agree with you Don but depends on what finish you put on.REGARDING CA GLUE, BOY I HATE THAT STUFF EVEN USING MEDIUM THICK WHEN I HAVE TO TO USE CA AT ALL IT ALWAYS LEAVE A SHINNEY SPOT I USE IT TO STRENTGHTEN PVA JOINTS THAT NEED REINFORCING BUT BOY IT CAN LEAVE A MESS, BEST TO USE WHERE HIDDEN, JUST ME . GOD BLESS STAY SAFE ALL DON
HI NIGEL WHAT BRAND DO YOU USE. GOD BLESS STAY SAFE YOU AND YOURS DON
Lovely work, and clever clamp blocking of the spirketting, at the foremast! It really is amazing to me how straight and stable the hull remains after removing the bulkheads.
It is also still really light, not like Sovereign which I need a crane to lift
Hey, I also introduced ZAP to my glue collection as a gel. It works very well in some tricky jobs.Don,I use Zap exclusively and use thin, medium and thick depending on the job.I never use accelerator, this can make a brittle glue even more brittle plus can cause discolouration,OK on a plastic model that is painted, not good on timber with a clear finish.
Kind Regards
Nigel
NIGEL, WHAT BRAND OF POLY DO YOU USE OVER CA,OR HOW DO YOU GET A FINISH WITH OUT THE SHINNY SPOTS. GOD BLESS STAY SAFE ALL DON
