Beautifull work Nigel,Just some pictures post Varnish.This item will need fully assembling before fitting to make life easier.One thin single coat of spirit based Poly applied with an artist brush.This is my plan for all the boxwood.The brown tint from the UV protection in the varnish will give the timber a nice caramel colour.
Kind Regards
Nigel
View attachment 331799View attachment 331800View attachment 331801
Especially keeping in mind the scale, no this is not the 1:36 St Phillippe. Great work.
For miniature carving I use this Eschebach glasses which you can adjust per eye.
It gives you macro vision but you only need to train you hand eye coordination due too the magnification.
Yes I wear glasses, therefore it is handy you can focus each eye separately. I remove my glasses when using this. I also have jewelers goggles but the are seriously heavy and I still have to wear my glasses as you cant focus each eye separately.Thanks Maarten
Do you wear glasses and if so do you remove them when wearing these?
Kind Regards
Nigel
You have different versions of the eschenbach goggles.
I have the max detail, it magnifies 2x. For me this is sufficient. The larger the magnification the more difficult your hand eye coordination.What magnification do you use Maaten, I have looked online and ones like yours are only 2X that I can find ?
Kind regards
Nigel
This all looks very good. I love the contrast. My books are all still packed away. Are you using JCL’s butt shift and planking layout?
You know, it’s interesting because maple gives you enough color variation to add visual interest to the decking without the distraction of poorly scaled open-grain structure. Cherry can be good like that, as well, but Maple will age better and attain a nice golden patina, over time.
This is a great instance where applied logic leads to a more sensible construction, and easierYes and no Marc, I followed JCL's Saint Philippe design regarding binding strakes and that the band either side of the centre on has the most tapering.Planking shift and length is random as per Saint Philippe but not a direct copy as the deck shape is a little different.
I am deviating from the deck design show by JCL's SP as he shows a raised, domed centre with further hatch framing on top for the lower gun deck.JB's L'Ambiteux has the only the decks above raised in the middle, the lower gun deck is flush with raised hatch frames.
I understand the decks above having a raised centre, these act to help channel water away from the gratings but I see no merit in this channel if the hatch frames are already proud and there are no gratings
Kind Regards
Nigel
