Nigel, superb work as usual from you my friend.![]()
Thanks Brian
Kind Regards
Nigel
Wonderful work,but I did not understand why do you use a kit to build this model. In the moment you use only a few of the bulkheads for your model. Why do you build the model not only following the drawings?
Hall Nigel,
I remember. I did not know the casts but if I see your possibilities to carf, I could not believe that they are so good, that you need them.
I know what such a kit costs and that you also pay for all the things you will not use...
But it is your decision and I am happy that I have a very interesting build log to read.
Very interesting Nigel. I think I learn something from every single one of your posts...tinted(?) veneers...I had reservations and also headaches around getting a result that I would find acceptable for the blue areas of the hull.
Last weekend I had one of those lightbulb moments so checked out what coloured Veneer I could find to cut the upper hull planking from.A couple of days ago my dark blue Tulipwood veneer landed.As you can see with no finish it is more or less Denim colour but the last picture shows the colour with varnish applied which is pretty darn close to what I am after.
Kind Regards
Nigel
View attachment 333185View attachment 333186View attachment 333187
Just taking a look at the stock kit imagery, it occurs to me that AL did something interesting with the arrangement of the wales; apart from the lower main wales (2 wales), the middle and upper main wales are represented as single wales. I had not noticed that before.
Hi Nigel,Thanks Guys I think this is a positive step and there will be some colour variation plus I can micro bevel the edges to give distinction to the individual planks.
Marc,I held off replying and slept on what you said.I think that is a good idea and the other thing is that this veneer is available in a multitude of colours including white and black! Mmmm I think this is the way to go, if I have visible planking on the top, I really need it on the bottom.This will mean splicing veneer at the waterline and some serious spilling looking at Marc Yeu's build.
Kind Regards
Nigel
