That makes sense, concerning the false balcony.
Really? I don't get it. Why have a false balcony on a ship? Esthetics???That makes sense, concerning the false balcony.
Raw wood does not stand up to the ravages of age very well unless it is sealed to protect it from changes in moisture that typically come with the change in seasons. Look at what rain, dirt, dryness, and sunlight does to a bare picket wood fence. Dirt and stains can also enter the wood easily and ruin its appearance if the grain not properly sealed. Dirty water and oil can easily stain unprotected wood. When wood gets too dry, it shrinks and glue joints break. Great cycles in moisture will destroy a model within a decade if its materials are not protected.This might be a stupid question (I don't do wooden ships model, I'm a plastic guy), but why do you need to apply laquer to the wood piece?
Aren't some of those rooms from the pre refit soleil royal?Fabulous work, Nigel. I really like the use of the white veneer in the cabins. I take it you are using JCL’s SP as your guide, there.
To what degree do you think you might partition the interior, along these lines?
View attachment 347265View attachment 347266
It would require some scale extrapolation of the period French pied to come up with a layout, but it’s doable. To what degree it may be desirable is another question.
One could go nuts with a full doll-house interior and the famous coffered ceiling in the great cabin:
But, I suppose the priority would lay with what could reasonably be seen from above, and through the exposed deck framing.
