ThankyouGreat work !
Yes they sort of reflect practice of the time, Just a couple of things, firstly the deck follows the middle headrail, not the top, don't think at can do much about that. Secondly the aft most support is only 3mm from the bow planking and I wanted to fit a decent anchor bolster but have only 3mm, not sure if I can get away with cranking the frame so the top remains in the same place and the foot moves slightly forward by a few mm?One of the things I really like about the stock kit is that they do manage to give the headrails a pleasing shape and proportion that are consistent with the times. I also think the sweep of the headrail support timbers is pretty good.
It is not the worst thing, if the gratings have to follow the middle headrail. This is a compromise that my revised headrail design also forced me to.Yes they sort of reflect practice of the time, Just a couple of things, firstly the deck follows the middle headrail, not the top, don't think at can do much about that. Secondly the aft most support is only 3mm from the bow planking and I wanted to fit a decent anchor bolster but have only 3mm, not sure if I can get away with cranking the frame so the top remains in the same place and the foot moves slightly forward by a few mm?
One word: Genius.As a post dinner mini project, I decided to try an idea I had for scale working lanterns given the number of LEDs going into the model.Step by step, here is how I did it;
1- Filed the end of a 3mm yellow LED square and then squared the rim around the base, one side already has a flat on to denote the Cathode
2- Bonded a 3mm square piece of 0.5mm styrene to the flat end with medium CA
3- Bonded 0.5mm styrene round to the four corners with medium CA and trimmed the ends flush when set
4- Painted the Lantern "case" with Tamiya XF84 Dark Iron.
Success, I have a lantern that is 4mm x 4mm x 4mm. At 1/65, that is close enough for me.
Now just to repeat over 100 times
Kind Regards
Nigel
View attachment 348260View attachment 348261View attachment 348262View attachment 348263
Feel better my friend - ‘hope to see you back at her soon enough.
