USS Constitution by Model Shipways 1:76 scale
It's time for another progress report, I've completed the planking from the main rail to the top of the whale.
My plan was to plank the transom first, holding the hull like this made aligning the planks easier.
First plank in position, the side extensions will be fitted after the planks to insure that the transom curve is correct.
Transom complete the port lids are just dry fitted to check sizes.
The placement of the first plank is very important, I wanted to go from the gunport to the main rail without cutting down the planks.
This is how I setup the first plank, 5 planks down to the gunports and 3 up to the rail.
A 1/32" lip is required for the lids, when closed they must be flush with the hull.
I made a some brass pieces with a block of wood glued 1/32" away from the edge to position the planks between the ports.
Two more planks to finish this section then test fit the gunport lids to make sure they fit OK.
Last job is to cut out the upper deck gunports this turned out to be easier than I expected. First I used a micro saw then a file and finished it off with an aluminium L section with sandpaper stuck to it. Nice square corners and didn't take too long to do.
The whales will be next once I've worked out how to make them.
Thanks a lot for looking at this and any comments welcome.
Tony
Good morning Tony. Wow you are doing fantastic work here. Cheers Grant
Very accurate preparation - and very good execution and result -> you are on a very good way for getting a beautiful result!
work in progress....
Soon the "D" section or BELT D the lowest part: here I have a lot of questions..
Because in the user manual they are referring to sheet 4 for details but...nothing on sheet or plan4...
So I wil try to figure out how many, the width and thickness of the planks....
Or, Tony, did you already have a look into it?
Marc
Do you find it hard to work with such narrow planks?
Not at all: on the contrary.
I really enjoy working with these planks... It offers many advantages:
flexible
easy to sand to size
It makes it easier for you to correct mistakes.
But it is very labor intensive, in other words it takes a lot of time compared to the "standard" 3/32 x 3/16.
flexible
thank you for the feedback.
Marc
Hi Marc
Firstly your planking looks great. I've just finished the whales and you have nearly finished the hull, well done.
I could not see anything on plan 4 to help with the last section of planking. Plan 3 shows it's made up with 9 planks. Some of the planks are more than 1/8" wide at the stern so you may need some inserts in this area.
I'll be adding some photos this weekend.
Tony.
Good job - and congrats for finishing the hull planking - Looking very good
Hello Tony, Gentlemen,
Long time ago, everting ok?
I would like to get your advise.
I'm studying's the deck spar and would to define the color of it.
I found several colors going from brown to dark grey to light brown etc.....and following:
USS Constitution has four complete decks–spar, gun, berth, and orlop–that combine to make her about the height of a four-story building. The spar deck, or top deck, was originally made from a combination of white oak planking (to support the heavy weight of the carronades) with Carolina pitch pine flanking the hatches."
Hi Marc
Firstly congratulations on completing your hull it looks great. Two weeks is quite an achievement it took me that to do the whales.
The deck colour is difficult, it looks very different in depending on light and weather. I'm going to experiment with some different stains on the planks provided with the kit.
Tony
... I'm glad to hear you back... I was afraid you...
Indeed, the Hull planking went very smooth.
I followed the plan and this avoided to use a lot of stealers etc....
And, I don't need to use wood fillers ....
I am very curious to see your main wale realization... As I know you it will be perfect....
Hallo Tony,
Just for your info.
I'm fitting the plywood deck on the Hull.
But before installing the deck and perhaps starting the planking of it....I will first (next weekend) finish the sanding and paint the whole Hull with a primer.
Then looking for some beauty errors and eventual adding a little bit wood filler...
Hallo Tony,
Just for your info.
I was hoping not to paint mine. I don't know if that will be possible or not, though
