USS Pennsylvania (1837) Cross Section Scale: 1:64 [COMPLETED BUILD]
Yes but I cheated a little, I drilled the holes then filled with wood putty on this model. Sometimes I use brass wire and occasionally bamboo. I have a problem pulling bamboo through a drill plate. Arthritis does make some things a little painful.
Hi Mike
I built a couple of tools to help drew bamboo prior pulling it through a draw plate. I found it easier once I reached the drawplate to pull through.
http://www.shipsofscale.com/sosforums/viewtopic.php?f=89&t=1115&sid=6f04954033f0b120d0c5079803924e3f
Cheers
Geoff
Hi Geoff,
Thanks for posting your splitter jig. It looks like it will make the strips easier to run through the drawplate. I have a Byrnes Drawplate and have used it for several years. It does make good looking trunnels.
Mike
Main Wale & Exterior Planking:
The main wales were painted black on the ship but I wanted something a little different for the model so I used cardinal wood, it will darken over time. The planking is European beechwood and provides a nice contrast. The way I clamped everything together for gluing made for some interesting pictures.
IMG_3481.jpgIMG_3482.jpgIMG_3483.jpgIMG_3484.jpgIMG_3485.jpgIMG_3486.jpgIMG_3487.jpgIMG_3488.jpgIMG_3489.jpg​
Main Wale & Exterior Planking continued:
This is a few progress photos of the exterior and the finished planking.
IMG_3492.jpgIMG_3493.jpgIMG_3494.jpgIMG_3495.jpgIMG_3495.jpgIMG_3498.jpgIMG_3499.jpgIMG_3500.jpgIMG_3501.jpgIMG_3502.jpg​
Lower Deck Cannons:
The lower deck on the model shows four 8-inch chambered cannons. The following photos show the placement of the guns.
IMG_3511.jpgIMG_3512.jpgIMG_3513.jpgIMG_3514.jpgIMG_3515.jpgIMG_3516.jpgIMG_3517.jpg​
Main Deck Framing:
The main deck framing is quite a bit stronger than the lower deck as shown on the progress photos.
IMG_3518.jpgIMG_3519.jpgIMG_3520.jpgIMG_3521.jpgIMG_3522.jpgIMG_3523.jpgIMG_3524.jpgIMG_3525.jpgIMG_3526.jpgIMG_3527.jpgIMG_3528.jpg​
Main Deck Framing continuation:
This is a few more progress photos of the framing as completed.
IMG_3529.jpgIMG_3530.jpgIMG_3531.jpgIMG_3532.jpgIMG_3533.jpgIMG_3535.jpgIMG_3536.jpgIMG_3537.jpgIMG_3538.jpgIMG_3539.jpgIMG_3540.jpg​
Main Deck Planking:
The main deck planking including hatches with shot garlands and ladder access to the lower deck is shown on the following photos.
IMG_3541.jpgIMG_3542.jpgIMG_3543.jpgIMG_3544.jpgIMG_3545.jpgIMG_3546.jpgIMG_3547.jpgIMG_3548.jpgIMG_3549.jpgIMG_3550.jpg​
Main Deck Cannons:
The main deck on the model shows three 8-inch chambered cannons. The following photos show the placement of the guns.
IMG_3551.jpgIMG_3552.jpgIMG_3553.jpgIMG_3554.jpgIMG_3555.jpg​
Upper Deck Framing:
The upper deck framing progress photos is shown on the following photos. At this point it seems like the deck framing will go on forever.
IMG_3556.jpgIMG_3557.jpgIMG_3558.jpgIMG_3559.jpgIMG_3560.jpgIMG_3561.jpg​
Capstan:
This is a few photos showing the capstan assembly and the lower section temporally set in place on the upper deck.
IMG_3570.jpgIMG_3571.jpgIMG_3572.jpgIMG_3573.jpgIMG_3574.jpgIMG_3575.jpg​
Upper Deck Planking:
The upper deck planking progress photos is shown on the following photos.
IMG_3581.jpgIMG_3582.jpgIMG_3583.jpgIMG_3584.jpgIMG_3585.jpg​
Upper Deck Cannons:
The upper deck on the model shows four 8-inch chambered cannons. The following photos show the placement of the guns.
IMG_3586.jpgIMG_3587.jpgIMG_3588.jpg​
Spar Deck Framing:
IMG_3591.jpgIMG_3592.jpgIMG_3593.jpgIMG_3600.jpgIMG_3601.jpgIMG_3602.jpgIMG_3603.jpgIMG_3604.jpgIMG_3605.jpgIMG_3611.jpgIMG_3612.jpgIMG_3613.jpg​
