The fore gaff is ready:
All the bands made of 1.5mm/.06" wide brass strip.
With the unforgivable macros:
At the top the iron which is different from the main gaff (see insert right) with the 5mm/.2" double disc block. (Sorry, the picture is not fully sharp ......
At the bottom the 2 single disc 3mm/.12" blocks through which the two sheets of the topsail will soon run towards the bulwark.
At the end of the gaff:
On the left the band with the double 'ears' at the top, also with 2 single disc 3mm/.12" blocks for the sheets where they run from the sail via these 2 blocks to the 2 blocks at the claw. The lower 'ear' with the hole is for the downhaul of the gaff.
With also the 2 bolted bands with the 5mm/.2" single disc blocks for the peak halliard. Here the blocks hang with an eye in bands, the upper ends are secured with 0.6mm/.02" bolts. This is also different from the main gaff (see insert).
The top corner of the foresail is secured through the hole in the back.
