note to keep consistent all frames with BLUE ARE LAYER ONE, ALL FRAMES WITH RED LINES IS LAYER TWO,(BOW OR STERN). GOD BLESS STAY SAFE Dojn
I think for Don in this stage most important are the joint between the frame sections and not the total shape of the frame as there is plenty of wood left around the frame sections to still create the proper frame. Don I guess you are still glueing a new paper template on the frame before sanding these back to shape?@donfarr
Before the question gets answered, let us address some problems:
Frame 30
I can tell you that this frame is not going to fit.
You will have a major problem.
This frame will need to be redone.
Please look at the image below and write down what you see when you compare your frame and the inserted pattern.
Frame 1
I am not posting an image but, to a lesser extent, you will have a similar problem.
G
OK fraNo.2 i have taken it to very near completion, leaving a slight bit at tenon cut off and also at the top timber extension just cut one side off, leaving the other one not cut, also proof FRAME No.2 both first layer(BLUE) and 2nd layer(RED) sorry for the pins but as explained many times have to do it that way as i can not stand up very well unsuported so have to due it that wayb regardless as youn can see both layers line up at the joint lines and thye horizantal lines as another point of reference and i still need to now if i have done the top notch corectly need help in getting this right if someone maybe can draw it in the proper way would be GREAT, i will proof frame No.32 tomorrow along with other frames, COMMENTS ALWAYS NEEDED AND APRECIATED
As also mentioned previously be aware of working precise, especially with the notches in the frames for the mounting on the keel. These look to be off the centre line which will result in your frame not to be square on your keel.
