I totally agree Brian.I haven't cleaned these up yet and they look fantastic.The latticework is just under 1mm wide.
Kind Regards
Nigel
Kind Regards
Nigel
Funny thing how things appear and disappear, particularly in ship modellingJust a small update.
Three sides of the carving are now framed in Veneer but I have hit a wall.I have spent more time searching than building this weekend but cannot find my other Ebony section of the Prow.I propose just to hang fire until I find that "safe place" I put it.I am reluctant to remake as this would be a full 3 days work and I know it will turn up as soon as I have made a replacement
Kind Regards
Nigel
HI NIGEL SEE IF YOU CAN FIND MY EXACTO KNIFE MY FAVORITE ONE MAYBE IT LANDED 3,000 MILES AWAY LOL, SPEAKING OF KNIVES YOU SHOW ONE LOOKS LIKE A CMBANATION OF SCAPL AND NO.11 BLADE WHERE DID YOU GET IT. GOD BLESS STAY SAFE DON
Nigel, Extraordinary work thank you for sharing it, re putting things in a safe place I am ashamed to admit that I bought that angling plate for a Byrnes saw sometime ago and put it in a safe place, that I have now spent hours looking for this is playing with my mind, like did I really buy it ? or did I just plan on buying it ?
Your beautiful piece of wood will reveal itself when it’s good and ready. Best, Tony
Hopefully item will surface then if not before
Can you please explain me what is the benefit of this tactic instead of doing it with a milling machine?I fancied a change of tack this weekend but still moving in the right direction.Start of keel construction.After milling a stack of Pear and Ebony to the correct thickness billets I have started on the main keel scarph joints.I have taken pics of the process to show how I cut these in this large scale.The keel is 12.2mm wide by 13.5mm high.
After marking out the front slope is cut rough on the bandsaw.I then employ many cuts up to the pencil line again using the bandsaw.With waste broken away the face is then shaved using a scalpel with the piece in a vice.The nose of the scarph is then trimmed to final shape on the disc sander.
The final picture shows the joint glued together with Epoxy and clamped up in the vice whilst the glue sets.The timber is patchy as I have cleaned the excess glue off with a alcohol wipe.
Kind Regards
Nigel
View attachment 117537View attachment 117538View attachment 117540View attachment 117541View attachment 117542View attachment 117543View attachment 117544View attachment 117545View attachment 117546
Nigel has a milling machine... as far as I can see, but he's doing this new trick and I would like to know why the one is better than the other.Some of us don't have all the nice machines in our shop YET! I milling machine and lathe are next on my to get list for home shop.
GinoCan you please explain me what is the benefit of this tactic instead of doing it with a milling machine?
