Good progress!
then I started sawing the boards along the line of the drawing, Total 10 Frames.
Hey Mario!Very well done Shota! Coming alone quickly.
I use a Prooxon Dh 40, I'm very pleased with the device and its level of accuracy. The full technical details can be found on the company's website as well as in the blog I opened before the purchase last MayI am curious how accurate your Proxxon DH30 is from your first dialed in setting to start with and if you had to make some adjustments for your desired thickness. In shooting we would call that using Kentucky Windage which is a bad excuse for an improperly mounted and zeroed scope or red dot. ????? I have that problem with their FET table saw and don't like to waste wood with trials. PT-2
We learn from each other!Thank you so much friends for the compliments, I have a lot more to learn and that's why I'm here! I must learn from you dear friends
Sometimes with age added to age it is hard to remember what I forgot. PT-2We learn from each other!
age added to age
