|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Those deadeye chain plates look great with their taught and uniformly set placement. RichHere we go and I finally did dead eye chains. Hurrah . Unfortunately this is true only on one side so far.
Question for my curiosity... how were the gold scroll and lines on the black background board above the deadeyes done?????? they look perfect!!!!! RichHere we go and I finally did dead eye chains. Hurrah . Unfortunately this is true only on one side so far.
Thank you so much Scofiro for very nice feedback.Y.T. - I can’t tell you how much
Excellent painting job with precise crisp edges and no spiderweb creepers. RIch
Thanks. Using just a painting brush and occasionally the masking tape.Excellent painting job
That must have been a very small and fine pointed brush. RIchThanks. Using just a painting brush and occasionally the masking tape.
Nicely done on that small gun carriage with smooth falls in and out of the blocks. Rich
Nicely done. Rich2 mm blocks were purchased from Falkonet on eBay. Hooks are self made. Ropes are also self made.
Hi YT,In order to better understand curvatures of the hull I install "spiling battens". Spiling battens I use are thin wood strips which are straight and do not want to easily bend sideways. I use 0.5 x 5 mm wood strips. I lay them in such a way that they are not forced laterally whatsoever. I do so as I do not have intention to do lateral bending on any of the planks. I also do not plan making any of laterally curved planks with cutting plank pieces out of sheet wood material (too expensive, too much work and it is hardly a way historical shipwrights built their hulls - here I can be very wrong, but I do not know differently). I use a simplest planking technique.
The battens are simply attached to bulkheads with masking tape as you can see on pictures below. Masking tape was used instead of pins as it does not split my wood spiling battens.
View attachment 159476View attachment 159477View attachment 159478
What size thread did you start with in your rope walk to get the finished (three strand possibly) line? Nicely walked. Rich2 mm blocks were purchased from Falkonet on eBay. Hooks are self made. Ropes are also self made.
I use this rope walk. See picture.What size thread did you start with in your rope walk
