With sistered frames there is no need to install nails/bolts for structural purpose. In real practices they were bolted together. As Uwe pointed out, it's a matter of taste. Great work so far.Back from a holiday so back to my project...
Working on the rib's, and a question about these....
I believe that metal pin's were used to fixate the different parts together. In this case I expect that the different parts of the rib's needs pin's to make it strong. However, Michele didn't use pin's in de rib's in his model of the Commerce... Maybe because these are hardly visible when the rib's are so close together placed...
Looking foreward reading your opinions about this!
Hi Uwe,Usually these pins in the frames (of a model) are only for decoration, means to show and immitate the bolts used for the connection of the frame elements.
Normal wood glue keeps the parts together and are producing a good connection.
Also they are hardly visible, so most of modelers are not doing them, but it is (like often) a question of taste.....
I ave the same opinion - nice to know, that they would be there, but I think it is not worth to spend several days work for not visible bolts....Therefore I think it is better to just use the pins that are visible, so on the open side... What do you think?
Hi Uwe,I ave the same opinion - nice to know, that they would be there, but I think it is not worth to spend several days work for not visible bolts....
How do you blacken the heads of the brass pins after installation in the wood?
Hello Heinrich, thank you for the complement, I do not believe you need to be humble when I look at the work you do with your projects, very impressive...Hello Ronald. In my humble opinion, I do not think that you have nearly enough frames - even though you do plan on leaving the starboard side open. I would double the number and frames on the port side and see what that looks like before you make a call. By the way - the wooden window frames are beautiful!
Hi Oliver, the plan is to leave the starboard side almost entirely open. I want to create a complete interior, and to remain good visibility on this interior I need no create as much an open side as possible, but I also want to show the flow of the hull, so I need to find the right balance here....What is the plan exactly ? Open one side and let the other closed ?
Agree, the Windows are beautiful !
Hi Oliver,I think it´s impossible. Form follows function. Do it or loose it. I have the same problem. Kill the hull or hide the whole work of the interior. One side closed doesnt help because nobody will see this side on the wall. In my eyes the benfit to open the hull is much bigger than let it closed. The problem in my eyes is as well to show the details from the gundeck and the upperdeck. There are a lot of interesting details to show.
If you will open the hull, you have to build it complete, after mounting the shelfs and the wales you can cut the frames.
One little detail ! Your bolts from the frame arent correct. Take a look in the sections from the CdM and you will find the correct arrangement. The bolts for the floortimbers and the cross-chocks of the uprising frames arent shown in the planset. You have to look in alternative Monos or contempory documentation to get the correct positions.
Hi Uwe, thanks for the support! I agree, this way of building gives you a real insight about how real ships came together, a very rewarding feeling. Also the scale 1:48 makes it extra interesting….First of all you are making a very good job - in moment your model is looking like on a real ship yard when the shipwrights started to install the first frames - Great!
If you want to keep one side open, you definitely have to build all the frames of the other side with minimum the floor timber, on the open side you need the framing behind the wales and upwards. So I think you will have to make all the frames and cut out later the "windows"
There it is , why did I miss that one … I was looking in the added booklet…!!! Its important to build a symetric framework until the system get his own stiffness !!! Otherwise the frame will twist. It doesnet matter which wood you use for this. The risk is too high for that.
Planche 14
