No no. Don't buy it!Wow! I saw the old Mamoli Victory 1:90 for sale (I think they were asking $200 )
Understood. Back to watching your build...No no. Don't buy it!
I just completed one a few months ago. Same exact thing. It was missing parts, wood dried out and brittle. Unless you want to spend the equivalent to up grade, or more, don't waste your money. There are better models out there for your money.Wow! I saw the old Mamoli Victory 1:90 for sale (I think they were asking $200 ), but I don't think I have the skills to get it to this level.![]()
So many good ideas that I wish I would have thought of. Always learning.Experiments with jig for hammock crane soldering.
It is looking very good. Yuri.Don’t look so bad for first prototype.
Excellent work!!! How does one keep the heat from remelting a prior joint that is so close?
I use a heat sink as a piece of brass bar over the areas already soldered. Piece of brass also serves as a work piece holder.How does one keep the heat from remelting a prior joint that is so close?
the seller with the Mamoli kit is now asking $150... still passing on it though.
Very nice soldering with the jig and final piece. Rich (PT-2)
Only thing I do not like about this soldering process is that solder material is too soft and bends before the copper wire. I wish I was able to do a silver soldering here. However I do not know what material I could use for making a soldering jig that would not ignite at the torch flame. Any help here?Had done 8 pieces required of this size in no time. Blacken them too.
Great idea that I will remember. Rich (PT-2)I use a heat sink as a piece of brass bar over the areas already soldered. Piece of brass also serves as a work piece holder.
Hi YT,Only thing I do not like about this soldering process is that solder material is too soft and bends before the copper wire. I wish I was able to do a silver soldering here. However I do not know what material I could use for making a soldering jig that would not ignite at the torch flame. Any help here?
Hi Stephen, I wish I were in hot Australia now but... I am in cool Canada. Thanks for suggested solution. I did not see yet this material you mention around here. However you are right, there must be a material the jewelers use to have their trinkets soldered with gold or silver.you can get it from hardware shops over here in Australia.
