BLUENOSE by PIERO
Good evening guys, or good morning depending on where you are around the globe!
The first level deck is finished!
I have seen on some build logs that some planks have been placed and I believe that before proceeding with the main deck I will put them too. Some, alternate with respect to the upper deck.
See you soon (next deck ... probably)
Very challenging to see your build without the jig. Your are making a great progress. Now your pre-sanding and get rid of the char of the different beams pays out.
Indeed! I prefer to work with a free field around the model. It is important to keep the same distance between the frames but I followed your suggestion by placing the spacers without glue.
Piero that looks great! I am just amazed at the speed with which you work. Maybe you should pay Maranello a visit with some advice for the 2022 season!
Heinrich, it's a MUST for me! If I've to do a thing, I do that thing and nothing else ... I've been in Maranello .... but I prefer to build boats!!!
If you are not using the jig for the upper frames, then there is no reason to have the extra height. You can go ahead and trim them close to the final height. Which is…deck beam height + deck height + distance from the bottom of the scuppers on the bulwarks to the top of the bulwarks = height from the step (transition from two frames to one). Add about 5mm safety margin to that and cut off the rest. Just a suggestion to make working inside easier. ;)
View attachment 285043View attachment 285044
I think I'm gonna find myself a shelter where I can take cover and wait for this storm to be over.
As far as I can see there's definitely no good food, no good drink and no good .... for you in the near future.
Was wondering that as well. Sound advice.
One of the purposes of the jig, at least to me, is to have some control of the contours of the hull.
Have you any controls in place to ensure the frames maintain their proper alignment, relative to one another and left/right?
You're right Dean! I was thinking to do that, I wanna just fit the deck beam support then will cut the frames a few millimiter higher for safety margin.
Don't worry Johan, time to drink, eat and .... I always find it! As for yesterday, today and tomorrow!
Be sure to leave the proper height needed above the deck beams. That would be the deck board thickness plus the bulwarks (from bottom of scuppers to top of bulwarks. Then you can add a few to that. ;)
Looking at your jig-less set-up again, I couldn't help but wonder how you get the frames positioned correctly. The frames are oriented perpendicular to the waterline plane, the lower keel surface on the other hand has a small angle (alpha) (and is not parallel) to the waterline plane. Your keel clamping now gives you your reference plane, nothing wrong with that, which means that the frames have to be positioned with an angle 90 degrees minus alpha on the fwd side of the frames. (Measuring on the aft side it would be 90 degrees plus alpha.) Do you rely completely on the notches in the frames and the keel ánd the equidistant frames pacing, using spacers, or do you have other measures in place to ensure proper frame/keel alignment?
Using the jig, I rely on the notches in keel and frames to ensure location, where as the jig provides me with the means to ensure proper frame orientation, using spacers to keep the frames equidistant slightly below deck levels.
I know Johan, the jig test was made specifically to overcome all the calculations you made (90° ± xyz). And that's it!
If you look at the last pic, with the keel flat, the frames are slightly pointed towards the bow and if I raise it by xyz° I will have the waterline exactly orthogonal to the frames. When I decided to delete the jig I did exactly the calculations you did, and the xyz angle is almost 5°.
Here I raised and fixed the keel of the degrees necessary to have the waterline parallel to the flat, and I started to assemble the frames, one by one, using a 90° square to obtain orthogonality. Very simple and quick to make!
Hello Piero,
Thanks for your explanation, it makes it clear to understand what you did.
I think there are various ways to Rome (pun intended), and yours is as good as any, as long as you are able to maintain the proper relationships between keel and frames. And a jig is nothing but a means and not a goal in itself... ;)
Happy building!
Beer
G'day everybodies!
When I am at my home in Italy, and not having the "lab in the cave" available, I have to work on a table that I have inside a small room. Obviously I can only take small parts with me (I'm moving with public buses), so I complete the whole part of the deck' superstructure that do not need the availability of the hull.
Here is what was done in the morning.
Ciao!
