Today I added the ribs (26), after sanding, that go between the front spar and leading edge.
I used a spacer board to establish height and align the angle and location…
Then I ensured it was plumb using another board…
Then I added the pulleys. The instructions only mention drilling a hole for it in the main spar prior to adding the leading edge boards. But it’s so tight, I decided to paint and install it now while I can!
Then I glued on the leading edge boards after splicing them together.
After which I sanded, and sanded, and filed, and sanded…etc
View attachment 291614View attachment 291615View attachment 291616
It’s hard to see the profile, but if you hold it at the right angle, you will see it matches the rib profile and tapers towards the leading edge.
Whew! That was a lot of work. Now to do the wing tips and trailing edge.
