This definitely looks like a Bluenose, an astounding looking one at that, but a Bluenose for sure.Finally:
Cut free from the jig.
Saw off the upright parts and sanded everything flat with the bulwark.
Both parts merged.
In display position with the open side.
In display position with the closed side.
Thanxs, Stephan. It took some time, but now she shows her lines.Looks real good. Nice work![]()
Thanxs, Jan. The base is standing now, but more to come ........Fabulous, that will be an incredible display.
Thanxs, Johan. Unfortunately, the D.B.B.S. meeting was just a day to early. Otherwise you and Henk would have had the scoop with the life view.This definitely looks like a Bluenose, an astounding looking one at that, but a Bluenose for sure.
Your planning and craftsmanship is paying off.
Thanxs, Heinrich. Without words and just aI am completely running out of superlatives to describe your build, Peter! (and that is coming from an English teacher)!![]()
Thanxs Piero. Just a small raised shelf for today and this post.Great! Superb! Bellissima!
The whole podium is yours !!
No worries, Peter, Henk and I are privileged enough to be able to see your model real life.Thanxs, Johan. Unfortunately, the D.B.B.S. meeting was just a day to early. Otherwise you and Henkwould have had the scoop with the life view.
That is from both sides, because yours and Henk's are equally interesting to watch life.No worries, Peter, Henk and I are privileged enough to be able to see your model real life.![]()
This calls for celebration Peter! A milestone indeed! Have a drink on me, my glass is raised from across the sea!Finally:
Both parts merged.
Thanxs, Dean. Yes, closed a main chapter.This calls for celebration Peter! A milestone indeed! Have a drink on me, my glass is raised from across the sea!![]()
Now I am turning the page and looking for the next. At first I thought of working on the hull further, but decided to focus on planking the deck first. That's the easiest way for me now.
I am sure it is far better than paint, because it has transparency (like dye) that shows off the wood, and the nails upon close inspection. It’s hard to see that as well in photos, but I trust it is gorgeous in person!Another chapter finally closed Peter
Nice to see your BN live last week, your photos are always beautiful but seeing the red Ecoline color in real life was really amazing
For those who doubted the color and the Ecoline (Me) I can just say stunningly beautiful
Johan and I had the opportunity and I gained a lot of inspiration Friday
Regard
Henk
It's a pleasure to the eyes in real life, I can tell you.I am sure it is far better than paint, because it has transparency (like dye) that shows off the wood, and the nails upon close inspection. It’s hard to see that as well in photos, but I trust it is gorgeous in person!![]()
I prefer the darker wood, somehow it lends more character to your model.Before I start planking the deck, I first made a test sheet for the foredeck.
After the necessary measurements I came at 2.5 mm / 0.098" planks. They are max. 12 cm long, just like for the hull. That is max. over 12 frames.
Then I need 21 planks per half deck width on the widest part of the foredeck.
I had for that purpose Maple in mind and bought the necessary slats.
But according to this test, that wood is still too soft:"
It is the light wood in the lower part of the test sheet. Despite my new saw blade, it does not give a nice tight connection. Also the imitation treenails that I made with a 0.5 mm / 0.02" syringe does not give a nice tight image.
The top darker wood is what YQ supplied in the kit for the deck. But that consists of 2 large sheets: 1 for the half front deck and 1 for the half aft deck:
This is Red Beech.
In the lower part you can see that the wood has a drawing that continues over several planks.
From the remainder of the sheets I sawed some test slats. That is the darker wood in the test sheet.
Depending on the incidence of light, this also appears darker or lighter (see also above):
It has already received a layer of linseed oil. Also here the seams show some darker through the oil, so I don't have to make the sides black as caulking
That wood gives nice tight cuts and it draw the treenails tight.
I can turn the sheets over and saw slats from them. With all the leftover wood there, I can get the deck planked. That is also half planked on the port side with a certain pattern. With nibble boards where support is needed on the starboard side.
I also made the test sheet to practice inserting the plank ends into the strip against the waterways.
Regards, peter
If you are going for accuracy, I believe it was a lighter reddish brown. Of course it all depends on if Peter wants to take any liberties, or strictly adhere to what the ship had originally. Thus far he is following the history with accuracy, no liberties that I am aware of.I prefer the darker wood, somehow it lends more character to your model.
