Not a lot to show recently…been doing spring cleaning and yard work!
I did manage to get the landing gear installed.
I cleaned up the castings. Since the Brittania metal is soft, I decided to stiffen the struts with strips of wood on both sides. Then I drilled a hole in the wheel shafts, and inserted an aluminum rod. Those things made the entire assembly much more rigid. I now trust it to take the weight of the airplane with motor.
Then I painted and added the bungee rope for suspension and then added the tension cables…
