Sorry folks , been away for a week visiting my daughters and grandchildren in Melbourne ,    so the yard was closed but finished the 2nd planking and also planked the wales as with Mark took the measurements and distance from the lowest point on the Gun ports , I noticed he did the wales first , the rudder post at the moment a dry fit , also I added a 1x4mm strip in front of the rudder post to make it look neater , I noticed a similar set up in other posts , what you see is the “Raw Hull‘ no filler just some sanding , I might use sanding filler before painting and varnish .
