POF La Palme (L'Amarante) Corvette 1744 1:36 (Ancre Monograph) by Tobias
Hello dear friends of model making. After several attempts I managed to finish the bow, I think it should be 4.0 or so. Yes, I had my problems but I was able to achieve a reasonably good result. My first attempt was a few months ago and it was actually not bad, but I sanded it according to the instructions and probably a bit too much in the upper area. As I said, after a few attempts I was wiser. As I now know, it was not the sanding but the fitting of the individual parts, which in turn have no glue markings, and that was my problem as it now turned out. I also fixed the keelson and started with the limberboard (1x1mm), the inner planking will follow in the next few days.
Looks like a La Belle Poule in the photo above, Am I correct?
Sorry Jim it is La Renommee built by Petr Simek in scale 1:48 ;)
Hello everyone,
I have continued with the inner planks, one plank needs to be partially dovetailed by inserting boards to prevent debris from falling between the inner and outer planks.
First the plan of the inner planks
Adjust the plank and mill grooves at a 15 degree angle.
Gluing in the plank and waiting, during which I made the inlay boards.
Fitting and gluing the boards.
Thanks for all your likes and comments, have a nice Sunday.
Great detail with these small elements between the frames - not very often made by modelers - Great !!
Hello Uwe, thank you for the compliment, but I did it wrong and GD drew my attention to it today. I'll try to change it without making a big mess. I misinterpreted the plans.
