I love your approach to this model. Are you planning to improve the frieze decor on the upper hull?Hi All
I was determined not to buy any more kits as I have enough projects and pastimes to keep me going beyond retirement. However this release changed all that, I simply HAD to build it. Not because it is an amazing model straight out of the box but more a case that I realised the potential of the kit.
The kit supplied decoration has far more than a passing resemblance to the late Michel Saunier's model.His build is shown on MSW and Gerard Delecroix's forum.The quality of the castings is far greater than the one's you get in a current Mantua group model.It also includes some very fine photo etch details for bow and stern.
The biggest issue is that whilst the bow and stern are done well, everything in-between needs a redesign if you want a model that follow's French practice of the period. The gunport spacings are wrong, the deck Sheer is wrong and all the decks are enclosed on their ends, these would have most likely been open.
When the marketing video first appeared it stated 1/65, now the box and catalogue state 1/72?? So which is it? Working from the height between decks, this works out at 1/65.You cannot work from the model's length, the design for some reason has been shortened and the model is far too short for either scale.Given that the original is stated as having a length (gun deck) of 160 French feet, this model is at least 100mm too short.
It is my intention to redesign the kit's false keel to make the model the correct length and space out the kit bulkheads to compensate.The last few bulkheads at bow and stern will remain stock spacing as not to interfere with the kit decor.I am hoping that this "stretch" shall maintain the hull profile and just make the transition of curves a little more gradual.
I have already started to draw out the revised side view of the ship and have enough information established to start on the keel.The picture below shows the kit keel dry assembled on top of my work in progress drawing.In the next post I will show the extended version
Kind Regards
Nigel
View attachment 300503View attachment 300505
I imagine he'd have to replace some of the metal castings in order to make any improvements in detail, and that would be a lot of carving and small piece work. The casting s for this model look pretty good, and all you probably have to do is to add scratches on the plain metal surfaces to simulate wood grain texture in order to blend them in with the rest of the model and fill in some seam gaps. This model is splendid as-built right out of the box, but Nigel will add things to make it glorious.I love your approach to this model. Are you planning to improve the frieze decor on the upper hull?
Bill
Bill
So, in the final sheathing there will be very little projection of the boxwood wales above the blue planking; a very subtle step.
Cool - that’s an interesting detail concerning the LMW.Yes Marc, 0.5mm step.The bottom wale to the lower hull is flush. The projection of the Wales on kits is nearly always over exaggerated. The steps should be subtle on French ships.
This phase raises an interesting series of questions for me and I don’t know the correct answers: is the short planking of the balconies merely an extension of the deck planking on that level? If so, should it also reflect the tapering of the deck planking, as it comes aft? What would be the structural argument against balcony deck planking that runs athwartship?
