I think we all do!! We are responsible for those who have tamed.We call or dog "our child", I think that's how it describes the relation you have with a dog.
Thanks, Paul.This just looks SO GOOD Peter!
Thanks, Herman.Magnificent result Peter.
I used the same approach! No wonder I like the way these look!Thanks, Paul.
Sometimes I think: can't they fold that neatly? But I'm going for the look of temporary and quick storage, where the wind doesn't help.
Not to mention the folders trying to not fall off.Thanks, Paul.
I'm afraid I'll have to stop responding to your posts; a long time ago I ran out of superlatives. Again and again I'm trying to convince myself you're not a professional builder, your work is simply stunning.The topsail tied to the topmast hoops:
Measured the length of ropes for the sheets and the tacks and secured at the side and at an bottom.
Then fold the sail:
First lowered the hoops and fold the sail between them in zig-zag. Then pulled together with the help of the clewline.
Then further folded up and tied together with the binding string.
Before I could secure the sail to the mast, I first had to install the small spreader lifts:
They hang between the eyes on the top band and the spreader bars and each has 6 ratlines.
Then tied the sail to the mast.
The sheetcorner of the sail protrudes slightly. The port sheet will go straight down. The starboard sheet runs first over the main topmast stay and then down.
Thanks for pointing, Alf. Very good to bring that up. Just an example in a moment .......Not to mention the folders trying to not fall off.
Nice from you, Johan, to post an answer on our conversation this morning. I was also making one, because one of the found photos also showed an example of Alf's reply.I'm afraid I'll have to stop responding to your posts; a long time ago I ran out of superlatives. Again and again I'm trying to convince myself you're not a professional builder, your work is simply stunning.
What I did notice though (and already discussed with you through whatsapp this morning) are that the inner shrouds of spreader lifts run to the top of the lower front mast, instead of what I expected to the top of the top front mast. I was led astray by a) the Saga and b) pictures of the Bluenose II/III (the Saga obviously describes the BNII, so that should not be surprising).
I did find an old picture of the BNI, suggesting that your configuration is correct (this topic was evidently already covered by @Dean62).
The only thing is I still don't fully understand the reason why...
The red arrow pointing to the upper attachment of the spreader lifts (BNI), whereas the blue arrow points to where I thought they should attach to the top front mast (BNII).
It's not easy to discern, but in this picture it's evident the Bluenose I had the spreader lifts attached to the top of the lower front mast.
PS None of the pictures are mine.
And ......... you and the others: keep on posting, asking, pointing etc etc.I'm afraid I'll have to stop responding to your posts;
Thanks Mark. Only with the tissue layer, no sewing. It's to fragile for that.That looks like the way I fold a fitted bed sheet
Just kidding, great work on the sails Peter. A brave decision to go for the furled option, it worked a treat.
You also get to show us all your sewing skills as well now![]()
Thanks, Mark. In this way it becomes a full mast base where a lot of things come together.Very nice fit Peter, the gaff sits very comfortably against the mast![]()
Thanks, Maarten.You are the master of small scale sails and rigging Peter, just phenomenal.
Think I will keep to 1:48 and up![]()
Peter, were they actually rings or might they have been those U-shaped hook-thingies with a bent "hook" on each leg of the U. At this moment I can't remember what those were called. In any event if you care to look into those, a guy in Czechoslovakia (HIS Models) makes and sells photo etch sheets of those thingies. I have a sheet for my Revell America and think they are pretty nice.Thanks, Maarten.
For the most part, it remains to try and hope that things will work out. Which fortunately still gives a satisfactory result.
For general information:
I'm already thinking about the 3 front staysails. That's a different cake. Lots of little rings that are on the fronts of the sails and have to slide over the stays.
After making the foresail and attaching it to the mast with the boom and gaff, I'm not going to fully secure the foremast like I did with the mainmast. Certainly not yet with all the stays.
That means that I also have to make those staysails ready with boom, halliads, tacks, sheets, etc. To get the stays through all those rings and then secure them.
Usually you want to finish something, place it and then move on to the next thing. Not now .......
Regards, Pete
Hi Alf. Thanks for pointing, I know what you mean. I have seen the ‘hanks’ in The Saga pag. 33 as a kind of ‘halve moon mast hoops’ for rigging a Triangular Storm- or Riding sail. And the smaler ones on dif. pages for the jib sails.Peter, were they actually rings or might they have been those U-shaped hook-thingies with a bent "hook" on each leg of the U. At this moment I can't remember what those were called. In any event if you care to look into those, a guy in Czechoslovakia (HIS Models) makes and sells photo etch sheets of those thingies. I have a sheet for my Revell America and think they are pretty nice.
Hmm, a Bluenose in scale 1:48? Tempting, very tempting, although the Admiral might have different ideas...You are the master of small scale sails and rigging Peter, just phenomenal.
