Good morning @Steef66 , @shota70 and @Brian, thank you for the encouragement.I like these ones
French and belgian modelers like to use brass or iron nails to simulate nails, bots and also treenails.I would like to say that I have looked at a lot of construction reports of the Amarante in the French forum and almost all of them were made with iron nails. So I orientated myself on this and therefore did not concentrate on this color difference.
Hello Uwe that is absolutely correct and concerns the outside (planks) these are made under the waterline with tree nails and iron nails. I wrote to GD and he explained it to me as follows:BTW: your solution is looking very good - also the treenails made from two different woods - I like it very much
Das sieht doch sehr schön aus!Hello everyone, at the moment I have a lot to do and my job is very busy, which means that I can only rarely do anything at La Palme and Le Rochefort. As you know, I just started with the tree nails inside a while ago and I can only say 1/3 is done, hooray.
Good morning Tobia , I ask: is the bow to the left or to the right?Hello everyone, at the moment I have a lot to do and my job is very busy, which means that I can only rarely do anything at La Palme and Le Rochefort. As you know, I just started with the tree nails inside a while ago and I can only say 1/3 is done, hooray.
Hallo Tobias, mühselig ernährt sich das Eichhörnchen.Hello everyone, at the moment I have a lot to do and my job is very busy, which means that I can only rarely do anything at La Palme and Le Rochefort. As you know, I just started with the tree nails inside a while ago and I can only say 1/3 is done, hooray.
I took the liberty to ask you about the direction of the bow for the follow of the nailing, Thank You for Your kindness
