At last l can get round to (hopefully) answering your question. l can tell you the way l did it, and it worked for me. You need to have trimmed the frames down to their correct heights. You can get this by measuring each one from the keel up as marked on the 1:1 drawing of the side view. Also on the same drawing you will see two lines of little squares joined by dotted lines. These are the positions of the upper and lower deck beams. Obviously, the beams sit on the deck clamps, so the bottom of each square beam is the position for the top of the deck clamp which you can mark off on the inside of the hull from the top down. The deck clamps are fitted first followed by the strakes. Take the positions for these from the drawings on page 8 of the pdf manual which are remarkably accurate. They should start and finish as shown. Hope this helpsno problem Keef, get well soon.
M3,M4, M5 and M6 are positioned exactly as they are shown in the illustration on page 8 of the pdf manual downloaded from the internet.Hello Keef, thanks for that hope your feeling better! i think iv made a mistake in my question, its the lower strakes i can't position, M3, M4,M5,M6. if you can help i would really appreciate it.
Lezzers
Keefe, good afternoon.Hi everyone. At last here are some work-in-progress pics including quarter deck and forecastle beams, cathead, head timbers and lion figurehead. All work is still very much on-going at this stage, l just couldn't wait until the elements were finished to post the pics. The figurehead will lose that glossy effect when the stain has completely dried and will match in with the rest
Yes. lt's a scarf jointKeefe, good afternoon.
At first I thought that it seemed to me. But this is in two different photos. Is that the gunwale joint at this location?View attachment 361338
Vielen dank KarlHi Keith.
Sehr schöne Arbeit. Gratulation.
Karl
There is very little in the way of written instructions provided with this kit. A manual is available to download from the internet with 3D drawings of each part of the build. They are relatively easy to follow with a bit of thought. All the other details and measurements can be got from the excellent scale drawings of the hull, both side and top views. This is not the kit for a beginner
Hi Keith.
Please show the link for the PDF manual.
Thanks
Karl
Wow. Thank you very much for your kind words Heinrich. I really appreciate your comment and it gives me great encouragement to know you appreciate my work on this kit. Thank youHi Keith. It has been quite some time since I have last been following the forum in earnest. When I opened your log today, I was blown away by your progress and by the overall quality of this build. I have been wanting to tell you for this a while, and I think now is the time. In my opinion, this is the best POF hull structure build from a kit that I have seen on SOS! You fully deserve all the accolades that you have received for this build.
Hello Keef,There is very little in the way of written instructions provided with this kit. A manual is available to download from the internet with 3D drawings of each part of the build. They are relatively easy to follow with a bit of thought. All the other details and measurements can be got from the excellent scale drawings of the hull, both side and top views. This is not the kit for a beginner
