Thanks PaulNice to see you back at it Andre. Looking forward to seeing your progress - she is a real beauty as she sits today with a bright future.
Hi Kurt,Are you painting the hull after sanding out any issues it shows you?
They hull looked great in nature wood with a clear coat it would be a gem.
A fantastic build, and for ones -as I did -a ship with all Gunports open. I can only say" Bravo". One of the best builds in a long time.Applied Tamiya Fine Surface Primer to reveal glue residue and imperfections that may need sanding and/or additional wood filler.
I applied Humbrol Maskol around the gunport openings. We'll see how that works out. I assume I'll still need to do some touch-up painting on the gunports.
The Tamiya Surface Primer is a lacquer-based paint and I was a little worried about using acrylic paints for the top coat. From what I have read, I can still use acrylic paints if I sand the surface a bit. I'll test it out first.
Thank you Peaelcapi.A fantastic build, and for ones -as I did -a ship with all Gunports open. I can only say" Bravo". One of the best builds in a long time.
Nice work Andre. Great to see you are back working on the Vanguard.Applied Tamiya Fine Surface Primer to reveal glue residue and imperfections that may need sanding and/or additional wood filler.
Hi Chestcutter,Nice work Andre. Great to see you are back working on the Vanguard.
I follow your progress closely to assist with my build.
I also find all the painting types and processes somewhat confusing , challenging and a bit of trial and error.
I hate the error.
How long do you leave the Maskol in place?
I recommend you mark out your waterline before painting as this is not an easy step and is necessary to know where the paint stops and the copper starts.
Please keep posting pictures of your progres.
Excellent work!The Fine Surface primer did help to reveal some imperfections. I applied a little more wood filler and sanded those areas. I also applied a second coat of primer and then sanded the primer with 600 grit pads. I’m now ready to mark the waterline.
I decided to add the wood batten at the waterline. This is not in the kit’s instructions nor in Bob Hunt’s practicum. I have seen it on some models including in a photograph of a model of the HMS Bellona. This model was built during the ship’s major repair 1778-1780 and was used to demonstrate the practice of copper sheathing to King George III in 1778. The photo appears in Anatomy of the Ship series The 74-Gun Ship Bellona.
The top of the sheathing on a real ship, where it reached the waterline, was covered by a batten of 3 in2 elm. Three inches at 1/72 scale is approximately equal to 1 mm.
I didn’t want to use any stock material from my kit for fear of running out when it’s called for. So, I made it from 3/16” thick basswood. I set the fence on my small table saw to approximately 1.5 mm away from the blade and raised the blade a little more than 1.5 mm. Two passes on my table saw produced a 1.5 mm2 strip, which I sanded down to a little more than 1 mm2.
First pass.
Second pass.
Hi Fights-On,I've left maskol on plastic aircraft canopies for months with no negative effects. I will speculate that the warning to remove after a few days is based on it's shrinkage rather than any damage to surface underneath.
I am halfway thru 1st planking on same ship, and I cannot express enough how helpful I have found your build log and tips.
