- Aug 8, 2019
Hi Stephan,
Looking at the size of these tools they easily fit in an enveloppe![]()
...and it shouldn't be a huge charge for sipping being it an envelope! Is the place\person who collects the shipping address?
@everyone thanks for the likes and visit. Hope I give you some idea's to try.
Back to my build. I had the first part installed of the 3 layer (4th include the garboard strake) on the stern beam and it was time to measure everything out to see if my work was correct. There was already doubt by me on the back part of the planking. It looks to sharp and so the width of that part is to narrow. And indeed it was.
So a part of the planking needs a RE-DO!!
First thing to start with, was to take away the 3th layer I just glued before. That was easy the glue wasn't totally hardened out.
Then I cut in the second layer.
The boards already naturally bowed outward after sawing.
Above you hopefully can see the problem. The yellow line shows the width of the layers on that point. To frame 5 it is okay, but then it needs a bigger curve outwards on the second layer. After frame 11 (not visible in the picture) the planks are correct.
In these pictures you can see I only have to correct the second layer from 5 too 11. So I take out that part, make scarfs on the layer and put in a new plank with the correct curve. Sounds easy, but.... Lets find out and see. Hope I succeed on this one. Ill take a picture if the planks are off and the scarf joints are cut out.
