- Aug 8, 2019
Always impressive your rigging work. About the block for the clew lines.
If it is a clew line block or garnet block depend on the type of block.
In your case it is a clew line block. Because you used in your case a standard block. Like a bunt line block, leech line block. (On Dutch ships they don't use a leech line block but a turtle block, what is integrated with the yard)
A garnet block, a better name is a clew garnet block, looks different but has the same function.
This is a clew garnet block
The name garnet comes from the French word pomegranate, it looks like it.
You are sure to use on a French ship a standard block for this part of the rigging?
. Still a long way to go before I have to start rigging, luckily.
