Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
YesGreat craftsmanship Uwek. Did you use the Ecoline between the deck planks? Cheers
Beautiful work!some small more progress with installing the small beams etc.
The bowsprit is a dummy only to get a feeling
Many Thanks for your interest - to be continued .....
I am open for all comments and hints, negative and positiv - especially also related to the question of the hawse holes (which are already drilled off course
Hallo @Lucian29That sure looks like the real deal. Great work
The mast wedges were kept in place with some means or were just...wedged
On real ships I know the mast wedges were driven in to help hold and align the mast, but were they then cleaned up to look nice and even as often seen or just left uneven and rough?? Trying to learn the difference in real ship and model building.Many Thanks to @GrantTyler , @Mirek , @Bill Hime , @WojtasS , @Lucian29 and @Nomad for the kind words and interest, and also to everybody for the given likes
The main mast bitts were prepared
good that these bitts have to be fixed on top of the additional boards of the mast partners, so it can be preared completely and removed afterwards not to damage them
the small knees also fixed - final sanding after the "bolts" are installed (still some laser char visible)
more or less finished with temporary arrangment with mast and wedges
Many Thanks for the interest in my work on the CAF HMS Granado .... much appreciated .... to be continued .....
Hallo Kurt,On real ships I know the mast wedges were driven in to help hold and align the mast, but were they then cleaned up to look nice and even as often seen or just left uneven and rough?? Trying to learn the difference in real ship and model building.
Hi Uwe. You have added some very nice details around the mast with those wedged. Time consuming but with a great appearance.Hallo @Lucian29
sorry for the late reply, I was on a busianess trip over the weekend and had no chance to be online.
These wedges were really only wedged down and prodced the press forces against the mast and against the so called partners
on this photo you can see the "partners" - the wooden elements between the two deck beams
you can see also the gap (here too small and has to be widened) between the partners and the mast
The opening is often an octagon, so it can take over 8 wedges
the very rough (not at all sanded) wedges around the mast (8 wedges)
with the deck planking - but be aware, that the wedges are wedged towards the partners and not the planking
the 8 weddges from bellow without mast
with some adjustments of the thickness of the wedges, the mast angle was able to be slightly adjusted
so f.e. some thicker fore and thinner aft wedges , the mast would get a more inclination / rake towards aft - somehow finetuning of the sailing qualities
these topics can be also somehow interesting:
odd question?
What is the name of the round piece that goes at the base of the mast to cover voids and get a snug fit? and where can I find various sizes.? Thank you.shipsofscale.comMAST COLLARS
When a mast passed through an upper deck, logically a collar was present to prevent/ reduce the entry of sea water to the lower decks. Did lower decks have collars as well ? Peteshipsofscale.com
