Makes you wonder where the original shipbuilders got all the bent trees from.
Same place as the bent ones they used for knees
Oak trees are seldom straight unlike say Douglas fir
Hallo @Nek0Hello, I discovered this build log thanks to Marc (Hubac historian), and I will follow with great interest ! It's very exciting !
Kind regards,
Marc
Fabulous work, Nigel. I really like the use of the white veneer in the cabins. I take it you are using JCL’s SP as your guide, there.
To what degree do you think you might partition the interior, along these lines?
View attachment 347265View attachment 347266
It would require some scale extrapolation of the period French pied to come up with a layout, but it’s doable. To what degree it may be desirable is another question.
One could go nuts with a full doll-house interior and the famous coffered ceiling in the great cabin:
But, I suppose the priority would lay with what could reasonably be seen from above, and through the exposed deck framing.
Hi Hubac’s Historian,Fabulous work, Nigel. I really like the use of the white veneer in the cabins. I take it you are using JCL’s SP as your guide, there.
very impressive and clean. I sympathize with you in regards to photo etch lunacy. I am need deep in it now with my Bismarck. It is not moving as fast as I would like but such is life, I guess.I am having a change from photo etch lunacy on Akagi and continuing on with SR's lower hull planking.Just a few pictures (not very good) after blowing the dust off in preparation as it occurred to me I had got quite a bit further than my last update
Kind Regards
Nigel
View attachment 387101View attachment 387102View attachment 387103View attachment 387104
