Hello Tony,
Thx for the info but I would like to get your photo's: I solved it meanwhile.
An update on my part: today I finished the Transom as well as completed the Main Wale.
You will see that I (see stern) sanded the Main Wale flush with the Transom....
Everything has also been roughly sanded...in anticipation of the fine work.
I read in your previous message that you were going to figure out how to place the Main Wale.
I did it the following way:
The main wale consists of 7 strips (1/8" x 3/32"). I measured the distance on each bulkhead (sheet 3) and divided it by 7. This distance is the width of each strip on the respective bulkhead. So it's just a matter of sanding the strips to the correct width.
Special attention is needed for the Stern: here the strips are each 3/64" wide and should be bent slightly.
The same applies for the bow. I applied three strips
bulkhead F-K
bulkhead L-Stern
bulkhead A-F
bulkhead F-K
bulkhead L-Stern
bulkhead A-F
