Draw a sketch so I can understand what you are referring to.What did you use to mill the curve under the "hound" and the top of the cheek?
This is from page 49 or 50 of your log......Draw a sketch so I can understand what you are referring to.
Yuri, in the anchor stops you need to make indentations for the anchor claw- added the rests for anchors on the hull outside body.
I know. I intentionally did not do it as was afraid to screw them up. As they now installed it’s too late. The only tool that could do it good was a mill.Yuri, in the anchor stops you need to make indentations for the anchor claw
Good dayDraw a sketch so I can understand what you are referring to.
Hi. Sails were not a part of a Mamoli kit I have. So there is no drawings. As to wriggles above gun ports I made my own template out of wood and copied it with some epoxy paste for all the whole ship. You can roll back this building log. I show some details of how I did it.There are mising the sails and the parts that come on top of the cannon ports.
Here you go (drip shields)...Good day
I receive a a present a Mamoli 1:90 HMS Victory, but it did not come complete. There are mising the sails and the parts that come on top of the cannon ports. I made some with dental cement, but they did not work. (see the pictures of them) Does anyone knows if they are sold or have an extra ones i buy them, to make molds and copy them? (Sorry for my english). And also plans or drawings of the sails? Regards >From Medellin; Colombia
Thanks a lot!!!Hi. Sails were not a part of a Mamoli kit I have. So there is no drawings. As to wriggles above gun ports I made my own template out of wood and copied it with some epoxy paste for all the whole ship. You can roll back this building log. I show some details of how I did it.
Thank you PaulHere you go (drip shields)...
Cornwall Model Boats Ltd
Suppliers of quality model ship and model boat kits, model boats, model boat fittings, hardware, radio controlled and static display models available. Our Worldwide mail order service offers modellers with a large range of model ship kits, ship fittings, ship plans, building materials, books and...www.cornwallmodelboats.co.uk
I always check with HisModel.com. They usually have sails and cannons for various ships. Check with them. You'll be impressed!Good day
Thank you Bill, I will check it out. RegardsI always check with HisModel.com. They usually have sails and cannons for various ships. Check with them. You'll be impressed!
Bill
Are all the pieces brass? What type of solder did you use? The brass cranes that came with by Corel cross-section kit and brass rod do not want to take resin-core solder and do not make a good sound connection.Great idea that I will remember. Rich (PT-2)
Had done 8 pieces required of this size in no time. Blacken them too.
