Wonderfull work Tobias,
Your square nails do really look stunning.
Looking forward to you new false window stern, using black glass for these?
……a serious understatement from Paul…Very nice Tobias.
Cheers GrantYou can create the window frames with vineer on the boards to create not too much difference.Good morning Martin, thank you for your interest.
The rear section will be a challenge in many areas. Here are two pictures, one of my Le Coureur and one of Ricci's Amarante.
Image source: @Giampy65
As the area on L' Amarante only has two windows, I think the combination with the black is very nice. With La Palme, the question now is, do I make it black as well? It might not look good with all the windows, and how do I design it, as the real windows are flush with the floorboards. But the fake windows are placed on top of the floorboards. Questions upon questions, there will have to be a lot of trial and error. I would be very happy to receive suggestions and ideas.
Nothing wrong with your old-fashioned craftsmanship, Tobias. This example of yours looks beautiful.Hello colleagues,
thank you very much for your interest and feedback. There is a bit of mass production going on, there are 46 iron angles on the program for the beams of the three tween decks. I already have 3.. In the French forum Daniel11 was kind enough to draw a plan of each angle to use for photo-etching. Unfortunately I don't have the necessary know-how, so I saw each individual angle out of a 1mm thick sheet of brass. Here is Daniel11's contribution including translation.
Hello,
for those who make the amaranth and make the fittings photo-etched, here are the values of the estimated angles at the level of the fold
from bow to stern
Step by step how I make my angles.
Hello Paul,That's incredible! Are you bending the brass to change the plane of the pieces? I assume so...
Is it necessary to thin the brass in the place it will be bent? How do you preserve the perfect angle?
……. a serious understatement from Paul and Grant……a serious understatement from Paul…. Very very nice Tobias
Cheers Grant
