So, is the Tooth Fairy real,The smaller Kingfisher (1771) (and the entire Swan class of ships) had them:
However, I'm much better at answering questions about orthodontic treatment...
The french ships were partly different - the Bonhomme Richard had not such a channel covered with these boardsWouldn't the Bonhomme Richard have had short Limber Boards to cover the Limber Channel, along the keel??
The Boudroit plans I have DO NOT show a Limber Channel but I believe all ships of this era had short Limber Boards (with holes to allow removal) running along the keel. These boards allowed access and cleaning (or un-clogging) of the Limber Channel.
Would it be wrong to include these on this build, as neither the ZHL Kit or the Boudroit plans have Limber Boards??
Take a look here into my building logI can't find these cross members. They are square cross members that go through the three small holes in the three main deck beams.
Are they cut from the 2x2 stock provided in the kit? It's hard to determine if they are laser cut pieces on one of the boards, which I can't seem to find. OR if they are cut from the 2x2 stock.
If cut from the stock, the instructions should NOT give them a part number. Instead, somewhere it should say cut from the 2x2 stock provided.
Any advice or help would be appreciated!!!
View attachment 440349View attachment 440350
Thanks Uwe, you are correct they are 2x2mm.Take a look here into my building log
when I remember correctly they are 2*2mm and no laser caut - laser cut makes no senseUSS BONHOMME RICHARD - POF - Cross Section in Pear - 1:48 - by Uwe
GREAT and BEAUTIFUL work UWE, hate to give advice to such a master builder such as YOU, because i have been a a RE=DO expert in taking things apart my procedure works well on both PVA and CA what i do is using NAIL POLISH REMOVER it has bto be 100% acotone i swab the joints with a cotton swab...shipsofscale.com
Good morning Brad. The good life, visiting all these wonderful locations and getting some boat building in as well. I'm a tad jealous right nowThe Beach Shipyard:
1. Dry fit of the Riser, pump room structure, lower deck beams. The only issue is the deck beams seem to be 1-2mm higher than the line drawn for the support plank, using the template provided in the kit. This template measures from the top of the frames which I'm not super confident in. I'll take some measurements from the keel and see if that moves the line. Everything else seems to be fitting VERY tightly!
2. Side view with Fiddlers Cove and Coronado Bridge in background.
3. Overview of the incredible shipyard location. We've been here for a week and leave for Colorado Sunday. The dog is enjoying the sun, sand and water!
Thanks Grant!!Good morning Brad. The good life, visiting all these wonderful locations and getting some boat building in as well. I'm a tad jealous right now. Cheers Grant
