Into the final few weeks of the hull build. It is almost finished!!. (well the hull is - the rigging will take another few months.....)
On a sunny day (yes it does stop raining sometimes!!) masked up the decking and took hull out in the garden and put it upside down on the old workmate (it is almost 45 years old!!) and using a clear matt varnish from PAINTfactory sprayed the ribs and keel. In all did 4 thin coats.
The bulwarks for the foredeck are made as a sub-assembly which I glued in position using a combination of super glue(for immediate fixing) and Gorilla glue - to fill in the gaps. The netting was fitted in place using small amounts of superglue.
Small admission - once I glued the bulwark in position next to the foredeck I realised I should have made a gap for the cannonade to fire through!
Quite pleased with the anchors - a nice Sunday afternoon job. As always glad I used to be a boy scout as this comes in handy making the rope lashings around the 1.5mm brown rope used as an anchor rope.
Made a cardboard template to cut the netting to size for the bowsprit netting.
Copied the Caldercraft Victory paint scheme to paint the entry port (Constant bugbear - Occre do not have any reference to painting schemes - only varnish)
Am not happy with the details of the guns on the top decks - Occre only show coils of ropes next to the guns whereas there should be blocks and tackle etc. Will look in the 'bit box' left over from the other Caldercraft Victory to find spare blocks
As you can see added other small finishing touches such as rope railing around the hold, more cannon balls etc
Note - photo no 633 in the instructions shows two racks of cannon balls on the inside edge of the bulwarks - I only had room for one as I had already fitted the stairs leading to the topdeck (as per photo 643). This was my fault as I got too keen and fitted the ladder too early. - the second rack of cannon balls fit partially behind the ladder (photo 643 from the instructions).
Spend a bit of time touching up some of the paintwork - still got some to do especially around the bows, think I will leave it until the rigging is completed so I can see what it looks like. Expect to use Yellow Ochre on the white timber strips on the keel
And that is about it for the hull - next posting the completed hull!
