HMS Victory by Occre build log
Just returned from a three month break from Modelling. Reason is I had completed the Hull and thought needed time out to do other things before returning to start the rigging.
During this period sorted out 'The Boat room' as my wife calls it by building a wall unit of cupboards. Made it out of 18mm ply screwed and glued together. Basically it is 4 boxes of ply joined together. Back is 9mm ply. Put shelves in also made of 18mm ply. Covered the edges with iron on oak strip. The top is a laminated Oak worktop normally used in kitchens. It should make my life a bit easier as I have alot of modelling 'stuff' to hide away. Once the Occre Victory is completed plan to make a glass fronted shelving unit on top of the worktop to display it in. Always thought the 'O' Level in woodwork would come in handy!!
Also made a unit to hold all of the different strips of wood/spars; every time I needed say a 2x2 strip had to rummage in the box to find it - wasted rather alot of time. So made a rack out of 18mm ply - the uprights have 15 no 20mm dia holes through which the strips of wood rest. Dymo labels used to label each size. Now every time I need a new strip its a matter of seconds to find the correct one - well worth the hour or so spent to make it out of scrap 18mm ply
After that quick division back to the model...........................
Completed the Bowsprit with no great problems. Only issue is bending the bands of metal used to create a banding effect around the main Bowsprit spar. Tried to glue them in position but found I needed to pin each end to keep them in position
All of it looks great !
How do you support the shelves in the middle of the "boxes"? I want to do something like that but am concerned about the weight the middle shelves can support.
Used these shelf supports - just drill a small hole and pop them in. If you want any more info re the plywood boxes just ask
Just realised you are the other side of the Atlantic - but expect you can get similar items there
Thanks. Yes, we have similar here.
Into the final few weeks of the hull build. It is almost finished!!. (well the hull is - the rigging will take another few months.....)
On a sunny day (yes it does stop raining sometimes!!) masked up the decking and took hull out in the garden and put it upside down on the old workmate (it is almost 45 years old!!) and using a clear matt varnish from PAINTfactory sprayed the ribs and keel. In all did 4 thin coats.
The bulwarks for the foredeck are made as a sub-assembly which I glued in position using a combination of super glue(for immediate fixing) and Gorilla glue - to fill in the gaps. The netting was fitted in place using small amounts of superglue.
Small admission - once I glued the bulwark in position next to the foredeck I realised I should have made a gap for the cannonade to fire through!
Quite pleased with the anchors - a nice Sunday afternoon job. As always glad I used to be a boy scout as this comes in handy making the rope lashings around the 1.5mm brown rope used as an anchor rope.
Made a cardboard template to cut the netting to size for the bowsprit netting.
Copied the Caldercraft Victory paint scheme to paint the entry port (Constant bugbear - Occre do not have any reference to painting schemes - only varnish)
Am not happy with the details of the guns on the top decks - Occre only show coils of ropes next to the guns whereas there should be blocks and tackle etc. Will look in the 'bit box' left over from the other Caldercraft Victory to find spare blocks
As you can see added other small finishing touches such as rope railing around the hold, more cannon balls etc
Note - photo no 633 in the instructions shows two racks of cannon balls on the inside edge of the bulwarks - I only had room for one as I had already fitted the stairs leading to the topdeck (as per photo 643). This was my fault as I got too keen and fitted the ladder too early. - the second rack of cannon balls fit partially behind the ladder (photo 643 from the instructions).
Spend a bit of time touching up some of the paintwork - still got some to do especially around the bows, think I will leave it until the rigging is completed so I can see what it looks like. Expect to use Yellow Ochre on the white timber strips on the keel
And that is about it for the hull - next posting the completed hull!
My old workmate beats yours, it dates back to '75/6.;):p
Incidently, Victory does not have exposed gun port frames.
Getting on with the masts. Reading the Victory book by McGowan made me realise Occre are taking short cuts in not supplying or using instructions to do certain features that the Caldercraft model has. Its almost as if Occre once the hull was complete thought - right that's enough - just need to do the rigging ASAP and job done. Am sure it will turn out OK but one does need to look at books to see what has been missed out
Wrapped 1mm thread around the bowsprit to hold it in place - tried to use the Gammoning technique - due to lack of space this was not as successful as it should have been - should have done this before the bowsprit decking was put in place. As you can see managed to route the cord through holes in the deck and the deck grating (note to myself - need to tidy thread up.)
Am using my 18 volt drill as a lath to turn the various masts while using sandpaper to cut them down to the correct size. Used some tape to make out the central areas of the spares where the size is unchanged.
Note - the instructions for Caldercraft are superb - they detail all of the various sizes/diameters of the spares. Occre doe not do this - you have to scale sizes off the drawings which is a bit of a pain!!
As you can see have used thin rod to help connect spars together - drilled a 1mm hole in the mast, inserted a small rob and glued the spare to this have first drilled a hole in the spare. Makes it simple to put spares in at right angles to the mast
Need to buy some 6 or 7mm double/treble blocks. Used these in the Caldercraft model to suspend the spars from the mast
Next step the mizzan mast - looking forward to getting all three masts in place - its coming on well..
Started to do the rigging on the foremast. Occre do not provide double or triple large blocks which are needed to raise and lower the main yard. So I bought some 7mm triple and 7mm double blocks from Cornwall model boats and used them, together with 0.75mm white thread left over from the Caldercraft Victory.
Started putting the shrouds complete with deadeyes in place; as you can see from the photos is very much work in progress but it is a start. Progress is slow as I had to remind myself of how it is done (threading shrouds in on alternate sides of the mast as one works down the line of deadeyes, using 0.25mm black thread to 'pinch' the shrouds together either side of the main mast)
Its going to take some time as it is a rather laborious process getting it all right with the shrouds to the correct length and the right tension.
As the Occre rigging instructions are almost non existent will use the Caldercraft ones for reference. Just do it one knot at a time
These instructions were pretty good when I built the first Victory - never done rigging before and it seemed to work out OK
Hi Julian. Thanks for the PDF. I am surprised to see the blocks, as per exemple on page 7, seemingly installed to present the hole upside-down. Am I wrong on this?
Ops - you are absolutely right - will have to be more careful in attaching blocks in future. Thanks for pointing this out - - it all helps in improving ones skills (or lack of!!)
Hi Julian
To avoid any doubt, it is easy enough to drill the second hole(s) in each block even after they are mounted if you do not want to retie them. It takes only a few seconds to do each one. Even with a block that is the correct size for a given application many of us have found the holes are sometimes too small for the correct size rope so have to be drilled anyway. Making your own blocks of course eliminates that problem and I would bet you can make blocks by hand that are far better than those in the kit.
Hi Julian
A good hint to rectivy this problem
and btw:
on the first model I made the same error and installed all blocks wrong....... so really an often done mistake
-> but afterwards you will make this error never ever ones more
Completed fitting the lower shrouds and started the ratlines - 176 knots made so far; about 1500+ to go!!. Can only do about 2/3 rows in a single session as it does my upper back in!! As you can see its very much work in progress as the shrouds etc need to be tidied up.
Still very glad I have my Caldercraft Victory to refer to as to how to do the rigging as the Occre instructions are non-existent - must say though they do have drawings of the rigging to use.
You are right. It is a suicide to do more than 2-4 rows a day. There are so many others things which can or have to be done too. Be cafull to cut the edges away
Tying knots on ratlines is best done with adjustable height table, as I have seen several others use.
I hope to get me one in the future, I have just one mast on my cross section and it wore my arms, shoulders and back out working up the mast.
Hi Julian
Hope you don't mind a question regarding the deadeyes in the tops. Do the plans call for a seizing in the top mast deadeyes to be above the tops? I have never seen this before, thus my question. From James Lees' Masting and Rigging, page 54: Before 1820 the futtock shrouds were hooked into the topmast deadeye plates which protruded just below the top. The below may make more sense than my wording.
Thanks
You are right of course re the deadeye on the futtock shrouds. Had thought of using deadeye strops but could not make it work (not enough room to fit - on the Caldercraft Victory they went into slots in the foretops which were covered by a strip of wood)
Occre have used the method I used - see 2.47 mins into this youtube video
Will look at it and see if I can make it more lifelike - problem is the tops are quite small and there is not much room to fit say two shrouds through a small hole on the edge of the tops
Thanks for the observation - it all helps.................
Hi Julian
I am not sure what you mean by fitting two shrouds through a small hole in the tops as the shrouds do not go through the holes in the tops. The deadeyes would be rigged similarly to those on the channels, with a metal strop to which the futtock shrouds are hooked. Sorry for the rough sketch
Hi Julian
I am not sure what you mean by fitting two shrouds through a small hole in the tops as the shrouds do not go through the holes in the tops. The deadeyes would be rigged similarly to those on the channels, with a strop to which the futtock shrouds are hooked. Sorry for the rough sketch
CORRECT ALLAN.
DO NOT MAKE THINK MORE DIFFICULT, THAN THEY ARE.-EL CAPI
