Thanks Uwe...coming from someone with your experience and expertise, it means a lot!I remember, that I also tried a longer time to find the "correct" way with the openings in the well box
Very good work
and enjoy ......
Very good work
and enjoy ......
No, I didn't make mine movable. For my particular build, I saw no reason to.2) The kit standard fixed piece from Signet's build which is awesome but I don't believe it functions. Signet can chime in if he made them movable. they obviously follow the photo from Boudriot's drawing.
I can think of no better reason for you to do this. I made a few changes from the kit too. Well done!Only reasons for the modifications are: To make the build last a little longer, add my interpretation of what certain details may have looked like and because it's fun.
I'll do a few tests when I get to the weather decks. (I can always erase the pencil lead) if it doesn't make any difference.I do the round-edge thing too, and feel that is enough at this scale without any blackening of any type.
Good morning Brad. You are owing this. Cheers GrantStill dryfitting!! The only thing glued to the frames are the mast steps/risers.
I've finally confirmed that the main deck cannons will be centered in the gunports. I was paranoid there might be small errors in the lower deck heights that would compound, to throw main deck off enough so the cannons would be too high or low, but they are spot on!!
Below are port/starboard pictures of the carpenters walk. It shows how the main gun deck beams ride perfectly on their support planks and fit tightly into the cutouts on the cabins and carpenters walk.
View attachment 446939View attachment 446940
The hardest piece so far, is the plank, with cutouts for the beams, in the left picture above (see arrow). That plank took an hour of careful chisel work but it will lock those beams in tightly. The opposite beam in the right picture is done but I didn't put it in to show the difference. I've dry fit both and clamped them down and they fit tightly.
Won't be long till I start glueing things permanently!!
