Thanks mateWhat a brilliant place to live (apart from the bushfires).
Viewed it mate, thanks for thatThere's an excellent planking tutorial on this site called Planking the Matthew. It's HERE.
Ah Hah !!Where’s all those planks then?
Ah Hah !!
I've been making a little progress mate, playing around a bit with different things here and there, and you'd be proud of me mate, I done-did my
first bit of "boat-bling"
Having put LED's in, the light from the open doors at the companionway would show an empty shell and a bunch of red and black spaghetti wiring,
so I decided to make a false wall with a handrail.
Thanks mate, means a lotOh well done! I like it. Simple and very effective with the planking inside lit up like that. You’re a star, old pal!
Is that any glue ?Did you read the part in my thread about quick setting the glue with heat
Thanks Bryian, I'll give that a tryYou can soak those planks in boiling water for a minute, then they are super bendy.
Is that any glue ?
I thought it was just that glue you were using (forget which)
I'm using PVA ????
I’ve never seen one of those before but it looks like the tool I’ve been waiting for. Thanks.Get a thermoaplicator, which is not an interchangeable thing in modeling, it is easy to bend slats with it, in some cases even on dry, it is also indispensable when gluing slats on carpentry glue, and plus it costs pennies.I recommend it to everyone, and I advise everyone to purchase it.
Nah mate, couldn't get it to work with the PVA, it was either the glue or my techniqueI’ve only used it with Titebond
Titebond
That's a massive boost to my confidence mateI’ve been thinking about that handrail and interior bulkhead of yours.
That's a massive boost to my confidence mate![]()
I think you've nailed it Smithy.simple scene setting
