There are other phrases also in common use like "loose cannon". When a cannon came loose in a rolling ship it could do terrible damage.Jim, according to google search;
The phrase "down the hatch" originates from nautical origins, referring to cargo being lowered into a ship's hatch, and evolved into a toast or encouragement to drink.
It gives nice contrasts in the woodwork, Donnie.Thank you all for the likes and compliments - greatly appreciated.
Starting the Deck Planking. Several pieces I already messed up and started over. The main point is deck COLOR. This is the combo I used and I am not saying this is the best. I am just saying that after different types of experiments, this is what I chose. Since I have a tendency to have little patience in this area, I opted for this combo. The pieces are being dry fitted - no glue up yet.
Taking a long raw strip of deck planking
1. Painting with stain (Dark Oak)
2. Painted with Weathered Gray Stain
3. Painted with another coat of Weathered Gray Stain.
lighted sanded a few strokes of 1000 grit. In some areas of the real ship, it does appear to have some very dark red streak in the planks, maybe its the lighting on the real ship. In some photos it looks like just plain gray painted over raw wood. At any rate, I am probably going to stick with this. The light sanding gives a little worn affect, but not much. I might go back and add a little more gray stain if need be.
As they say - - I think it is close enough for Government work !!!
I think one of the most surprising things to me getting into this hobby was how long these manufacturers sell the same kits for without ever updating design errors or instructions. Constitution is probably at the top of my list to build, but after seeing seeing modern kit designs like we see coming out of China and companies like Vanguard models, it's hard to go back to Model Expo kits using designs that are nearly unchanged for 30 plus years.Come on ME, lets make some changes here.
Hi Donnie,The box also has hull planking which is 1/16 x 1/8. I ran a few of these strips through my Micro Mark Table saw and trimmed off 1/32 off of one side which gave me a strip of 1/16 x 3/32 (which is same as deck strips). Given the 15 extra that I ordered (free) from ME (Model Expo)- I think I can make the deck work out ok.
In ME's defense, I will say that the PLANS are good. However, you are also given a box of wood and strips that a person MUST go through and study. The parts list DO tell you for instance (40 strips for decking, 50 strips for hull), ---- but ---- the rest of the wood in the box is a mystery as to HOW it is supposed to be used. If the parts list says (again as example) you have 5 pieces of 1/4 x 1/8 then the parts list should say these strips are for the HATCH FRAMES. This is not easily figured out --- however, I guess it is possible that I DID NOT study the entire set of plans enough to determine what strips or stock of wood should be used. Then also is another mystery: there is also ONE piece of like 3" x 3/32 solid plank of which I have no idea of what it is used for.
I really think that ME should at least hire someone with great experience to re evaluate the kit with its parts list being more specific, and also including the correct number of pieces to complete the project. The manual is severely out dated and I can understand that probably the manual was written WAY before computer graphics or CADD - ok, so, I get that 100%. But we live in a different world now that can show better graphics. The images in the manual are all HAND drawn of what I can tell. Please understand that I do not mean to be critical or harsh. Most of it remains that I admit that I am not a naval architect and this kit in the hands of someone that has done A LOT of scratch building "might" get it. As Bob Hunt said in his practicum a few times, even he was mystified on some of the things about the kit did not quite make any sense.
All I am saying is that for this kit to be really successful for those that are intermediate kit builders wanting to try something more difficult, the kit needs some serious overhaul. Otherwise, I would not nor could not recommend this kit to someone that had a clear understanding of how to be flexible and to modify on their own to make the kit a good project. I have already made a few trips to my local Hobby Lobby to get some basswood to make parts that the wood is not mentioned.
So in conclusion, in order to make this kit stand out, a lot of effort should be taken into consideration. One of the things I should have done is to make a paper template of the deck parameter and then DRAW out how all the deck planks were going to be arranged - as the deck planks will be tapered going aft to the stern. Yes, you can calculate what the width of each strip would be in order to squeeze the exact amount - but it is more difficult to that as we know that there will be tolerances to deal with. If a person had the time and being so careful, they can take a plastic ships type curve to lay out all the planking on the paper template, but that would take several days to accomplish - and I admit that I just did not want to invest that much time - instead I just chose the "seat of my pants"approach. I really do not want this project to turn into a multi year project as I have other things I want to get involved with.
I agree with you this kit can be very frustrating. Nearly every part has to be carefully planned with little or no instruction. I kinda wish I had the practicum but I find my best source for help is all the other build logs.The box also has hull planking which is 1/16 x 1/8. I ran a few of these strips through my Micro Mark Table saw and trimmed off 1/32 off of one side which gave me a strip of 1/16 x 3/32 (which is same as deck strips). Given the 15 extra that I ordered (free) from ME (Model Expo)- I think I can make the deck work out ok.
What? are you going to take up knitting?no more ship models.
Of course, that can get expensive too. My wife was looking at a sewing machine that was about $8K USD ! LOLHi Donnie,So, this falls into the dilemma of being happy with it and not happy with it. The deck looks better in real life than the pics do. Yes, I know that there are areas that look worn - but I might add some more gray later on.
However, when the deck furnishings get added along with the Cannons, Bitts, and rails, and what not , alot of this will not even be noticed or even seen. Lets just say that it is a well worn ship ! HA.
The Deck would have turned out A LOT better if this kit had a "False Ply Deck" to mount your deck strips to - like what OcCre does. This should be the first thing Model Shipways should do to this kit.
After working on this, I am tempted to say to myself, no more ship models.
So here is the "Ugly Deck".
I hope you don’t mind me sharing a few thoughts about the deck. One of the key parts of building a model is deciding early on how you want to present it. That initial planning shapes everything, especially when it comes to how the hull and deck will work together visually.So, this falls into the dilemma of being happy with it and not happy with it. The deck looks better in real life than the pics do. Yes, I know that there are areas that look worn - but I might add some more gray later on.
