HMS Victory of Caldercraft by Wil
30 Making Mast Components
Meanwhile, I’ve started looking into the masts and rigging. There are still quite a few challenges here, like the mizzen topgallant yard, which needs to taper over 49.5 mm from 2.3 mm to 1 mm, with the diameter reduced in proper proportions. I wonder if this will work and stay intact, it’s so thin. But we’ll see.
This week, I started making the wooden mast components. Months ago, I bought a small Proxxon lathe for a bargain. However, the lathe is too short to make some mast parts at full length. Additionally, the 10 mm feed diameter limits me in making the lower sections of the bowsprit, mainmast, and foremast, as these are 12.7 mm at their thickest.
So I disassembled the lathe and mounted the drive and carriage separately on a plank. By moving only the carriage, I can now adapt the machine to any desired length.
For the masts, I created a kind of production sheet, in which I recorded the modeling and measurements. This makes things easier than working from large drawing sheets.
The 12.7 mm dowels from the kit turned out to be slightly warped. Luckily, I still had some old dowels of that size that were straight. After tapering the ends, they were ready to use.
First, all relevant measurements are marked on the dowel, such as transitions from cylindrical to tapered and square. The taper is measured using a standard division.
Next, the wood is tapered with a narrow gouge near the reference marks until nearly the desired thickness. The bottom of this tapered area is darkened with a pencil to remain visible during turning.
After approaching the black lines with chisels and gouges, sanding blocks are used in grits from 80 to 220.
Once the entire dowel is tapered, it’s finished with 240 grit sandpaper. That completes the turning for this mast part.
Above, I showed how I tackle the round tapering of masts. But mast parts also include sections that are square or even octagonal. Here's how I addressed that:
It seemed easiest to perform this while the workpiece is still in the lathe. The key is the position of the nut that drives the chuck. I filed a notch in one corner of the nut, which becomes the reference point to keep track of the rotation.
I made a small template that fits the lathe’s nut, allowing me to rotate the workpiece 90 degrees at a time. In each position, a flat side can be sanded onto the workpiece with a sanding board.
Next, the tapered section where the octagon is needed is turned.
To add the octagonal shape, I made a similar template, but with the nut’s hole rotated 45 degrees.
With the final result:
Yesterday, I turned the last parts on the lathe. I really enjoy this work, but the topgallant masts presented some issues. They’re very thin compared to other parts, and unsurprisingly, I had to remake several of them. They keep breaking just before they're done. Grrr…
True turning with a chisel is limited, it’s more filing and sanding while the piece spins. That causes a lot of wobbling with such long, thin rods. A fixed tailstock isn’t a solution either, because the workpiece is often too thin (about 2 mm) to handle sideways forces.
The best option, in my opinion, is to gently support the end by hand so it can flex slightly. And don’t apply too much pressure with tools. You learn that naturally after starting over a few times.
The photos below give a nice overview of the mast parts that are “finished” so far. From top to bottom: foremast, mainmast, and mizzen.
Good evening Wil. This is fantastic. Thanks for the detailed log as well. Cheers Grant
I meant to mention something. Although this may not be of any use since you are making the yards from wood, whereas my medium is mostly 3D printing, I have had great success strengthening yards with carbon fibre rod and bar as thin as 1mm. If you're able to bore a 1mm hole for most of the dowels length, you could insert a CF rod (glue with superphatic glue) and this will make the yard considerably more stiff for turning to shape. It's possible to buy 100mm long drill bits down to 0.5mm diameter, if you search the web for "extra long micro drill bits"
31 Assembling the Masts
Over the past few weeks, I was able to continue working on the masts. After the turning and filing of the conical, square, and octagonal parts, the lower masts are now finished, including the bowsprit. Then I could begin assembling the various parts onto these mast sections.
Below is an impression of what is currently on the workbench.
On the ship, it looks like this.
Sharp-eyed viewers will notice that the eccentric bulges for the bowsprit’s seizings are still much too thick. These were not easy to make. I clamped a 12 mm dowel tightly into a hardwood plank, drilled some off-center holes, and then enlarged them to 12.5 mm. What remained were eccentric shell sections that are now on the bowsprit. These will be neatly sanded into shape using the disk sander.
Continuing with the lower masts and the first section of the bowsprit. Structurally, these are mostly complete. What’s still missing are a few eye bolts.
I’ll check everything again before painting this section.
32 The Tops
Since I was already working on the masts, I moved on to the tops. Love this part of the process. First, I cut all the pieces, deburred them, and did a dry fit. The drawing looks like this.
To properly place all the beams on the tops, I transferred everything from the drawing to tracing paper and marked the positions on the wood.
After adding all the beams, it looked like this.
Once all protruding parts were removed and the cross trees glued in place, the next picture was taken. Don’t worry, the trestletrees aren’t glued yet.
Once the glue had dried, I couldn’t wait to hang the tops on the masts. I first glued one trestletree to each mast and made sure it faced the correct direction (horizontal toward the keel). Once that glue had dried, I glued the other trestletree, using the position of the top to determine placement and alignment.
This was the result. And yes, the tops can still be removed later.
32 The Tops
Good morning Wil. Looking very impressive. Your tops are fantastic. Cheers Grant
Hello Wil, your DB250 'mod', gave me inspiration to do something with mine. I unscrewed the headstock, then remounted it using only the first two screws, extending the bed by 80mm. I do have a bigger wood lathe for bigger jobs, so this was a worthwhile mod. Thanks for the idea!
Stuart
33 The Bowsprit
A sharp observer pointed out that I made a mistake with the blocks at the bees on the bowsprit. I appreciated the keen observation. It quickly became clear that I had indeed made a few errors. I think I know why. I found it strange that I had one leftover part, but that happens more often than you'd think.
My solutions:
  • The pulley I installed is useless and will be sealed off.
  • I can thicken the cap on the starboard side to create the attachment for the Flying Jibboom.
  • The semicircular cutout for the Jackstaff is now clearly shown in Longridge's drawing.
  • As for the bees: the two angled bees must be removed. On top of the bowsprit, against the cap, goes the leftover part. This part is as wide as the bowsprit at that point. I need to recess the pulley wheels into the wood. On port and starboard, the pulleys will be covered with a strip, and on top of that, the two angled bees will return.
  • I also took the opportunity to adjust the saddle for the Spritsail Yard Sling, which didn’t look right either.
I immediately tackled the bowsprit with a small renovation. The photos speak for themselves.
I also made the other mast parts of the bowsprit, from bottom to top:
  • Bowsprit
  • Jibboom
  • Flying jibboom
  • Dolphin striker
  • Jackstaff
Because the Jackstaff is so thin, I made it from a 2 mm brass rod and tapered it.
Now the bowsprit is ready in all its components.
Next up is finishing the various parts and preparing them for assembly and painting Leaving aside the rigging and blocks for now.
Good idea, Wil, using a brass rod for the jack staff. Must make a note for when I get there. Incidentally, is it me or has anyone of you fellow 'Caldercraft Victory' builders found the stern 'plume', top decoration to be out of scale - too long? I'm just making the lantern brackets using photos, but on dry fitting I found the deco. interfered with their position, it also appears too long if the relevant positioning in relation to the window is compared.
Stuart
PS. I have just confirmed that the'Trophy of Arms', is too big, so have just ordered a 3D resin printed set of stern decorations from Woody's Model Works.
34 Studying
At this point, a lot of information is coming together, and I must say, it's hard to keep everything straight.
My sources include:
  • Caldercraft build instructions
  • Book "Historische Scheepsmodellen" by zu Mondfeld (Dutch)
  • Book "Masten, Blokken & Tuigage" by Orazio Curti (Dutch)
  • Book "Rigging Period Fore and Aft Craft Models" by L. Petersson
  • Book "The 100-Gun Ship Victory" by John McKay
  • Book "The Anatomy of Nelson's Ship" by Longridge
  • Caldercraft drawings (Dutch and English versions) provided by Jan Zwart
That's more than enough material, I think.
Discussions about what more I should or shouldn't use, I'm setting aside for now. There are surely other useful books, but this seems sufficient for now.
Now, a question:
Earlier, I wrote that the eye bolts supplied in the kit are very thin and fragile. They are made of brass and listed as 0.3 mm in the parts list. I used a few of these on the guns. I also purchased larger eye bolts, which I used in various parts of the deck. These larger ones seem way too big in relation to the masts and future yards. On the other hand, the smaller ones seem better in scale but too flimsy for tensioned rigging.
Does anyone have experience with these, possibly with both sizes? What do you recommend?
Meanwhile, I spent a few more hours on the masts. Tidied up some remaining issues and painted everything.
Yesterday, I placed the masts into the hull, and now I finally see how massive this model is going to be.
35 The Rigging
Another topic is the rigging. I read somewhere that the diameter of the rope in practice depends on its function. I need to find the source again. Since I'm making my own rope, I must ensure it matches the correct scale.
Caldercraft’s manual assumes a fixed set of rope diameters: 0.1, 0.25, 0.50, 0.75, 1.00, 1.3, 1.8, and 2.5 mm, included in the kit. My gut tells me that in real world the variation is much finer. The steps in the kit are too linear. Since I’m making the rope myself, it’s a great challenge to get this right, I can control the final diameters. From the master builders, I understand that getting the proportions right plays a crucial role in the final result.
So, I spent the last few days digging into the 13 drawings that cover masts and rigging. The woodwork is still manageable, but the rigging and blocks are much trickier. Caldercraft's kit has wonderful materials, but the manual is mediocre. The hull drawings were self-explanatory, but this is different.
The rigging is divided into six phases, each with an overview of required blocks, ropes, etc. The first four phases are easy to follow. But phases 5 and 6 lack the parts lists and these include most of the blocks and rigging. So I need to manually inventory everything from the drawings. But it’s not always clear whether it's a single or double block.
I'm also considering replacing the blocks included in the kit.
Question: Can someone explain how I should approach this phase of the project, ignoring the detailed aspects like knots, seizings, etc.?
I think I’ll have the McKay drawings enlarged. It’s nearly impossible to work from them as they are. The tables, I’ll convert to Excel so I can include proper Dutch terminology and measurements.
Yes, it’s a lot of work, but it will help me better understand everything.
Are all the ropes listed in McKay’s tables meant for a fully rigged ship with sails.
My model will have no sails, so perhaps I can omit some of them. Is that correct?
In other words, this will be a lot of studying, but enjoyable too. It helps me get into it.
The last few months, every spare hour has gone into this. Currently, I’m juggling several subjects, but rope has dominated the past few weeks.
First, I converted McKay’s rigging table for the Victory into Excel. A big job, as it’s handwritten and the PDF isn’t always sharp. A fun study to get immersed in. I’m currently working on translating the various terms.
Alongside choosing to make my own rope, I also delved into the actual rigging used on the Victory. McKay provides a wonderful overview on pages 116 to 119 of all ropes, their sizes, finishes, etc. To be clear, it covers 258 different functions, often doubled for port and starboard or even more (like shrouds). That likely means around 500 ropes in total. A massive task, by the looks of it.
To better showcase the work done on the model, I decided not to show fully deployed sails. That would obscure the view of the masts and rigging. Nor will I include the setup for studding sails. Instead, the sails will be displayed reefed (rolled up). This means the number of rigging functions can be reduced to 168.
Based on McKay’s table and the book by zu Mondfeld, I’ve spent the last few months studying the routing of ropes, how and where they are belayed, what thicknesses are used, and which blocks are needed. Along with some additional drawings, I’ve developed a clear picture of what goes where. Even just naming all the ropes was a massive task, but it has brought me a lot closer to mastering the subject.
36 Current Status
Since January 3rd this year, I have taken you all on SOS through 35 summary chapters about my project with the Victory.
In reality, however, I actually started building this magnificent ship back in March 2022. A more detailed report can be found in my Dutch build log: https://www.modelbouwforum.nl/threads/hms-victory-van-caldercraft-door-wil.281364/
Just for the record, up to this point:
• Over the past 3.5 years, I have worked on my shipyard on 385 different days
• So far, I have spent a total of 1,465 hours working on the Victory
• I feel like I’m about halfway there now
Designing and making various tools and aids has been an important addition to the building process for me.
From now on, my posts will be much less frequent and this build log will run in parallel with my Dutch report.
I wish all my followers lots of reading enjoyment in the future.
Hello everyone,
Anyone who has the above-mentioned machine will certainly be annoyed that it is not possible to turn or grind 1:48 scale masts (in my case, Le Requien masts) on it. I gave this some thought and would like to share my solution with you.
First, I ordered the machine bed as a spare part from Proxxon. The part arrived two days later. I screwed the existing machine onto a board and removed the cover cap.
Now I cut a strip of multiplex plywood to 10x10mm and inserted it into the rear opening of the profile. This ensures that the two profiles are joined together so that they are perfectly aligned. I supported this by additionally clamping the tailstock onto the joint.
I then screwed the profile onto the wooden panel and refitted the cover.
This gives me 650 mm of space between the tips. That should be enough for the masts and yards. It worked great on the main mast of Le Requien.
I hope you find this tip useful. I would just like to point out that you should be very careful when sanding. Otherwise, you'll end up with kindling.
Greetings Rüdiger
Hello Everybody,
A small addition to the Proxxon woodturning lathe. I designed a Lynette for the long masts and printed it with a 3D printer. Now everything is a little easier.
Greetings
Rüdiger
26 The hammocks
In between jobs, I am fiercely studying how to do it all later with all those ropes. To be continued.
Anyway we pick up where we left off. There were still two sloops in half, which still had to be finished. And I had an idea how I was going to make the hammocks, which should be in the nets. Again, my idea started with the application of bandage gauze. After all, the kit says nothing about the nets and the hammocks and then filling things in as you see fit is also a lot of fun.
My intention was to make small rolls of 3 to 4 mm in diameter and approx. 8 mm in length from gauze. The starting point is gauze that is 8 cm wide and not elastic. From this you cut strips about 6 cm long. And you coat these with diluted wood glue, which has been coloured. In my case, I had some left over from the nets. The idea behind it is that the hammocks on the ship will not have been too clean over time and there will be some nuance in this as well.
I then took a 1 mm bar of brass and rolled the smeared gauze around it as tightly as possible.
Then set this roll aside and carefully pull out the brass bar and let the roll harden. Hard is a big word here, because the highly diluted wood glue keeps the roll somewhat flexible
After a day, the rolls have hardened and the excess can be cut off with sharp scissors. Then cut the rolls into pieces, I vary a little between 8 and 10 mm, so 9 to 10 hammocks will come out of 1 roll.
And then it's packing. Depending on the depth of the nets, I put 0, 1 or 2 layers horizontally at the bottom and alternately 2 horizontally and 3 vertically on top. All vertical is also possible, of course. In fact, varying a little will be more realistic.
I made the hammocks that are in the nets in the photos above yesterday and put them in the nets quite soon after, when they were actually not quite cured yet. No patience of course. The effect, though, is that they are then much more elastic and allow themselves to form nicely. Yesterday at the end of the day, I processed the 19 rolls shown in previous photos. Those were slightly harder this morning, but I think doable. Trimming in both cases went very well with the Japanese kitchen knife, which works like a guillotine and which I also use to trim all my laths etc. Razor-sharp and cuts great.
I currently have 28 rolls of material, good for about 250 hammocks. I estimate enough for half a Victory. For nuance in colour (degree of soiling), I want to apply some darker wood glue here and there at the end, and for fixing I want to apply matt floor varnish. We'll see.
After a few days, all the nets were filled with these hammocks. I did not count them, but estimate that there will be about 500. Although I was dreading it quite a bit beforehand, this part turned out to be much better than I expected. Now that I look at the photos again, they look like huge bales of straw. The sleek look of the hull so far has been somewhat destroyed by this, which is a pity I think. I really have to get used to this "messy" addition. On the other hand, once all the ropework is in place and huge amounts of rope have been put up here and there on the deck, it will not be so bad, I hope.
With this, my hull is now almost finished. In fact, only the hatches remain to be fitted. The nets and hammocks are a personal addition, as the kit does not provide these (only the black brackets are
Outstanding job so far!
in the kit). I believe this definitely adds some
37 The Serving Tool
In the meantime, I have been working on building a serving machine, based on the example of Stephan (Steef66), who wrote an article about this. A very good tutorial by Stephan can also be found on SOS: https://shipsofscale.com/sosforums/threads/serving-tool.7615/
A very clear explanation that works well as both a construction guide and a reference. Not too difficult for us handy types, provided you have the right materials.
This project was more or less my first independent experience with AliExpress. Many different components in various sizes. It seemed like a nice challenge to order everything this way. Well, I certainly found out. I’ll spare you the details, but from day one I was buried in emails from the Far East. Each email referred to just one component. It turned out that the order was shipped from multiple locations. I hadn’t paid enough attention during ordering and ended up with many different suppliers, each adding their own shipping costs. Some items were suddenly no longer deliverable because of “transport issues.” Getting a refund? Not a chance. Long story short: an expensive lesson. But well, that’s part of the experience now and then.
After several weeks everything finally arrived, and I could get started. My Victory will need a huge number of served lines, so this machine will be a very useful tool.
As a starting point, I used a full 1-meter M5 threaded rod. This results in about 80 cm of free length between the two halves of the machine. Perhaps a bit large, but better too big than too small. I have no idea yet how long the pieces I’ll need to serve will be. Plenty of workspace, at least.
The machine is now finished, and this afternoon I served my first rope, see the photo series below.
And the final result, photographed with the macro lens:
What I still want to do is create a number of clamping aids to hold blocks and similar pieces. I already have a few ideas.
This week I also bought new blocks, because I am not satisfied with the ones included in the kit. Although Caldercraft supplies very good materials, this is definitely an area that could be improved.
Now the real work can begin.
  1. First, determine the correct settings per rope diameter for my ropewalk;
  2. Then twist the rope to the desired diameter and bake it;
  3. Add blocks and serving details;
  4. Install everything on the ship.
38 Making Rope
In recent months I have also spent a lot of time making rope. I am now about 175 ropes further into practice, and I think I am beginning to understand, read to feel,how it works. I’ve experimented a lot with speeds, but especially with counterweights.
Where at first I was afraid of using too much counterweight, it turned out this fear was unfounded. My conclusion: better more than too little. Of course, there are limits, if the thread snaps, it’s too much. A useful effect of extra tension is that the natural stretch in the fibers compensates for minor differences in tension between individual strands (looser strands will not immediately fall outside the ply). This quickly improves rope quality.
My learning process has taken almost six months so far, during which I was very busy with many things besides model building. And as the number of ropes grew and I felt I was getting the hang of it, it actually became more enjoyable, a perfect distraction from my busy work.
I now have a nice collection of ropes: 3×1, 3×2, 3×3 … up to 3×9 and 3×10 strands, from 0.2 to 1.00 mm. My thread is Gütermann Skala in colors 702 (black), 464 (beige), and 696 (brown), in thicknesses 200, 240, and 360.
All usable ropes are wound on pieces of cardboard and sorted into storage boxes.
As you can see, I also experimented with cable-laid ropes: 3×3×4 and 3×3×6, with diameters of 1.25 and 1.45 mm. Now that I understand this process, it won’t be difficult to closely match the required dimensions using McKay’s tables.
The first set of ropes has also been baked. Five minutes in the oven at 150°C worked perfectly. I tied the ends together and wrapped them around an empty tin can, held by a few clips. I was very curious about the result. Before baking, the individual fibers spring in all directions when the rope is cut, but after baking the rope stays perfectly in shape. The “reprogramming” of the polyester fibers works flawlessly. In the photos the rope ends are not glued—just untreated.
The rope also becomes slightly thinner: from 0.45 mm before baking to 0.40 mm after. The rope feels good and even has a bit of stretch, which will be very useful during rigging.
