Very good and precision joinery work,Uwe!
This sounds interesting - can you maybe show us a photo of this "airbrush with sand blasting nozzle" ?I tried several ways to remove char from joinery. I found any sanding tends to round out the flat surface, it seems the edges get sanded faster than the rest of the surface. I use a single edge razor blade and scrape the surface that works better than sanding. I realize not everyone had an airbrush but I have a sand blasting nozzle on my airbrush and a quick pass over the parts and BAM! the char is totally gone. The sanding grit hits the surface all at once so there is no rounding off the edges.
Hallo my friend,Ciao, ottimo lavoro, una cosa non ho capito, ma i pezzi li tagli tu al laser oppure è un kit? Scusa la mia ignoranza
google translation:
Hi, great job, one thing I didn't understand, but you cut the pieces to the laser or is it a kit? Excuse my ignorance
That sounds interesting Dave, but even then the frames still have to be hand sanded to get an even surface for laying the planks on, and I find that by sanding the char off this way the char gives a guide to what area's to sand,I tried several ways to remove char from joinery. I found any sanding tends to round out the flat surface, it seems the edges get sanded faster than the rest of the surface. I use a single edge razor blade and scrape the surface that works better than sanding. I realize not everyone had an airbrush but I have a sand blasting nozzle on my airbrush and a quick pass over the parts and BAM! the char is totally gone. The sanding grit hits the surface all at once so there is no rounding off the edges.
You are right with the frames, and when you are sanding the hulls form. I think, that this sandblasting would be very useful for the joints preparation of the timbers and futtocks of each frame......and other areas, where it is not easy to reachThat sounds interesting Dave, but even then the frames still have to be hand sanded to get an even surface for laying the planks on, and I find that by sanding the char off this way the char gives a guide to what area's to sand,
Best regards John,
Until now I made the preliminary sanding of the frames with my spindle sander - so the work was done by the machineHow was your Pear wood to sand, my Cherry was really hard, I started off with 120 grit sandpaper but ended up with 40 grit for the basic removal of the char and to get the frames level across their width and finished with the 120 grit, I am pleased with the way they have finished, just got to do the insides now, ,
Best regards john,
Many thanks for the information and your opinion - highly appreciated.Uwe
As you know the frames are not truly typical of sistered frame construction due to the scarph.Normally with sistered frames there are three bolts spaced evenly in each overlap centrally piercing both frames.Some variation on this could be possible.Scarphs are bolted through the scarph.
I think you just have to go with what is aesthetically pleasing as the kit design is not true to reality.
I did choose not to portray bolts on Saint Philippe after much consideration,I felt their size at 1/36 would draw the eye and detract from the joinery even with such a small gap between frames.
It is all down to personal preference,in your model if I was going to show bolting,I would probably have gone for just three bolts equally in each overlap.You could show the bolts cross bolting the scarphs but visually you would have lines of bolts one side of the joint on the outside of the hull which would possibly be unpleasing to the eye.
Kind Regards
Nigel
Dave may answer better, as I don't have experience with sandblasters. But to me, this looks more like a gravity feed airbrush with a large paint container. For sand, this will be too small (IMHO).Dave is this the sand blaster? It’s $27.99 at Harbor Freight
I have to check in the drawings! Either kit and / or Boudriot ....She is coming on nicely Uwe, it is surprising how much work there is in these sections.
I was wondering if you had any idea what size the wood is that support the decks I will attach a pic of what I mean, I think they might be 7x3mm but not sure,
best regards John,
