USS BONHOMME RICHARD - POF - Cross Section in Pear - 1:48 - by Uwe
I tried several ways to remove char from joinery. I found any sanding tends to round out the flat surface, it seems the edges get sanded faster than the rest of the surface. I use a single edge razor blade and scrape the surface that works better than sanding. I realize not everyone had an airbrush but I have a sand blasting nozzle on my airbrush and a quick pass over the parts and BAM! the char is totally gone. The sanding grit hits the surface all at once so there is no rounding off the edges.
This sounds interesting - can you maybe show us a photo of this "airbrush with sand blasting nozzle" ?
Ciao, ottimo lavoro, una cosa non ho capito, ma i pezzi li tagli tu al laser oppure è un kit? Scusa la mia ignoranza :)
google translation:
Hi, great job, one thing I didn't understand, but you cut the pieces to the laser or is it a kit? Excuse my ignorance
Hallo my friend,
no problem -
Yes! It is a kit from a chinese manufacturer - take a look at this topic, where I introduce the kit:
That sounds interesting Dave, but even then the frames still have to be hand sanded to get an even surface for laying the planks on, and I find that by sanding the char off this way the char gives a guide to what area's to sand,
Best regards John,
Best regards John,
You are right with the frames, and when you are sanding the hulls form. I think, that this sandblasting would be very useful for the joints preparation of the timbers and futtocks of each frame......and other areas, where it is not easy to reach
How was your Pear wood to sand, my Cherry was really hard, I started off with 120 grit sandpaper but ended up with 40 grit for the basic removal of the char and to get the frames level across their width and finished with the 120 grit, I am pleased with the way they have finished, just got to do the insides now, ,
Best regards john,
Best regards john,
Until now I made the preliminary sanding of the frames with my spindle sander - so the work was done by the machine :cool: I think there is in moment a 240 grid sandpaper installed - getting a beautiful surface
But read also the following post
Yesterday I made only some smaller progress, with cleaning and sanding the face sides of the frames - I had to remove the pencil marks and the rests of the glue and paper, which were stick during gluing. Here I used 240 grid and later 320 grid (by hand) to get everything removed.
In addition I made a trial and wanted to show some bolts holding the timbers and futtocks together - this I made on one side of the frame number two which is covered by frame 1 and 3 - so that I could check if they will be visible later one
Now the check if they are visible
here an enlargement of the same photo (incl. brightening to see it better) - ad the ends of the red arrows you can slightly see the "bolts"
Hardly to see, so I decided not to make them on the frames 2 to 8. I will show them later on on the frames 1 and 9 - at the visible front sides of the section
I have a question to you all and want some advice and information - I was thinking about how would be the real bolting of such a joint.
Due to the fact, that such a double frame has two layers, where the joints of the other layer is displaced / staggered there should be additional heads of "bolts" visible, or? Like a marked it red (dotts)IMG_41471.jpg
here I borrowed one photo from John, where the displacement of the two half of the frame can be seen very good (John, I hope this is ok for you?)
Uwe
As you know the frames are not truly typical of sistered frame construction due to the scarph.Normally with sistered frames there are three bolts spaced evenly in each overlap centrally piercing both frames.Some variation on this could be possible.Scarphs are bolted through the scarph.
I think you just have to go with what is aesthetically pleasing as the kit design is not true to reality.
I did choose not to portray bolts on Saint Philippe after much consideration,I felt their size at 1/36 would draw the eye and detract from the joinery even with such a small gap between frames.
It is all down to personal preference,in your model if I was going to show bolting,I would probably have gone for just three bolts equally in each overlap.You could show the bolts cross bolting the scarphs but visually you would have lines of bolts one side of the joint on the outside of the hull which would possibly be unpleasing to the eye.
Kind Regards
Nigel
Uwe
Kind Regards
Nigel
Many thanks for the information and your opinion - highly appreciated.
These kind of joints were not used in the french construction, you are right, but were partly used at english ships (I think).......It is hard decision, but I am able to shift it a little bit until a far later stage of the construction, due to the fact, that I will only show them at the outer frames 1 and 9 or at the outside of the hull (either way where I will make them.
Yesterday I installed the frames and glued them together with the spacers. Keel and keelson are only fixed with some rubber bands, I want to remove them partly so I can sand the frames without damaging these parts.
This board shows the levels of the gunports, for later markings with pencil
At the back you can see the drawing of the cross section
The rubber bands the press the keel and keelson towards the frames
the construction for the spacers, so they are all in the same height - nice idea
and I found my old friend - the shipyard supervisor - he started already to check the measurements
Many Thanks for your interest ..... to be continued
She is coming on nicely Uwe, it is surprising how much work there is in these sections.
I was wondering if you had any idea what size the wood is that support the decks I will attach a pic of what I mean, I think they might be 7x3mm but not sure,
best regards John,
Dave is this the sand blaster? It’s $27.99 at Harbor Freight
Dave may answer better, as I don't have experience with sandblasters. But to me, this looks more like a gravity feed airbrush with a large paint container. For sand, this will be too small (IMHO). :cool:
No, it’s listed as a air eraser/etching kit and the description says “it operates like a small sand blaster but more accurate”. It’s item # 69277 on the harbor freight website. The reviews are good and people ar3 using baking soda, and aluminum oxide 220-240 grit media in it. It needs 65psi though so a small airbrush compressor probably won’t do it.....
best regards John,
I have to check in the drawings! Either kit and / or Boudriot ....
and you are correct - It is still a lot of hours working on this model
Hi Uwe, I have just checked the kit drawing and the wood supplied in my kits and there is only enough 7x3mm to do the wales but they have 6x2mm strips running all the way up the inside of the frames and they are just sitting the beams on them, see pic 56 in the instructions, I should have spotted this earlier,
Best regards John,
Yesterday I sanded the outside area of the frames, this part above the spacers - at the end I did it by hand without power tool. Takes much more time, but I think that the result is better
afterwards I removed the elements of the jig which kept the spacersticks in the correct height - so do not glue this part of the jig
