hi all more progress pictures and a call for help please, showing frame No.3 not sure if I have it done corectly, so do need help so many lines it can get confusing as i like to bevel the frames after installing all of them, also showing the building slip i am using got it last year but have not used it until now, i changed the screws from hex head to phillips head screws easier to do, will have to move it into my bedroom when i start to instal the frames SORRY MOSES (MY CAT and companion), QUESTION FOR MIKE41, noticed you did some frame plans from a ANCRA BUILD and you marked the CLAMP LOCATIONS, how do you determine the location from the orignal plans WOULD APPRECIATE SOME HELP and coments
I always write a k on the end of the futtock that goes towards the keel,not all are obvious as to which way round they go
(the red PDF)". Open the document, scroll down to page 75 and you will find a lot of information about building frames. The ship is different than what you are building but the information can still be applied.
