I tried to capture the fact that jig slot,slots in the base of the frames and gap between hawse timbers all line up perfectly to take the keel.Not so easy to capture on camera.I am pleasantly relieved everything has worked as intended.
Thank you very much, my friend, much appreciated!!!Thankyou Jim and Happy Birthday mate
All the best
Nigel
Rough faired?!?! I've never seen a model so beautifully shaped. Nigel, there is some force at work here, besides your patience. I understand you are not willing to share that force, that's OK. In the meantime, I'll crawl back to my hole and never surface again. Happy birthday Jim!Thankyou Oliver and Maarten
I cut out the crossmembers between the frames to gain access to the inside.The inside shape has been rough faired.I am going to order a shaped cabinet scraper to refine the lines.
Kind Regards
Nigel
View attachment 141621View attachment 141622View attachment 141623View attachment 141624
