LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
Hello Nersch, Thank you that you like the reports and are helpful, I am very happy. regarding the frame construction, both halves are built as precisely as possible. While gluing the individual joints, I measure again and again and compare them with the plan. Then I build an auxiliary keel to have a fixed point and glue both halves as precisely as possible. The emphasis is on as good as possible, because you'll have minimal tolerances, so it's important to leave some flesh. The most important thing is the sanding, I make the colored plan and that is my absolute point of reference. For me, the main focus (Le Rochefort) is on the yellow frame, which is always at the top when sanding. i.e. I grind it down to the line and so I have my correct shape of the frame, the blue side, i.e. the back, doesn't interest me, even if, for example, the line is no longer visible on one side and about 0,5mm on the other. However, you have to take this into account if you have to grind the inner shape, i.e. the slope of the inside. I hope I was able to describe it clearly.
With Le Rochefort 1:36, the total width is 10.6mm, so half is 5.3mm. I used 5.5mm, i.e. 11mm in total, then I ground it to 10.6mm.
Hello Tobias,
Thank you very much for this detailed and clearly described explanation for the frame making. Understood and noted for my own build
When first grinding to the yellow line, are you going exactly to the line or do you leave some flesh for the final sanding, when the hull is finished?
I prepared already some wood for my frames, but it is already at the final dimension, so nothing left for a final sanding.
Do you think this will still work or shall I prepare new wood and use the existing wood for something else in the future?
Thanks, Tobias!
What du you think about the thickness?
I prepared my wood already with the final thickness, so nothing left for sanding in thickness.
Would you recommend to prepare new wood?
Thanks, Tobias!
No I wouldn't do that. At La Palme I think I had 5mm wide frame halves and I used 5mm boards. Sometimes the thickness was 5.17mm, sometimes only 4.86mm. By applying the thin layer of glue, it automatically becomes a little stronger, not really visible to the eye, but measurable. If a frame is 1-2 tenths thinner, I don't think anyone can tell.
Hallo all,
Last week I was for some days on a business trip in Bavaria and had the chance to visit our friend @Tobias at home.
Many thanks for the hospitality and the visit in your workshop - and I can confirm, that his models are looking really as good as in his building logs
His La Palme in his hands - on the first photo you can also see on the desk his Le Coureur
POF La Palme (L'Amarante) Corvette 1744 1:36 (Ancre Monograph) by Tobias
Hello, everyone. Here I would like to introduce you to my second project, I am trying to build the La Palme, a sister ship of the L' Amarante. I hope that I get a lot of input from you to identify any errors and to fix them. Le Coureur will continue to be built whenever I need a change. Now...
shipsofscale.com
and also the Le Rochefort group build model stands close to the Coureur
Really good to see two smiling faces enjoying your wonderful models Tobias with your special guest Uwe @Uwek. Your workshop is a great reflection of your neat and keen attention to detail in your ship building.
Hello everyone,
I wish you a wonderful good evening. I've been more into La Palme lately, now I want to go back to Le Rochefort and I can say half the frames are done. I need about 1 hour per frame -> the marking of the bolts and the recess that are milled. Then of course the milling and drilling, setting bolts, grinding and polishing and then blackening the bolts. Everything that eats up a lot of time.
Now I wish you all a nice Easter and have fun looking for the eggs and chocolate bunnies.
Hello @Ptèr , thank you very much for your visit here at the group building Le Rochefort and your kind words, much appreciated. Well, I promised you that it will continue soon, here at Le Rochefort. Today it's time to clean up and rearrange the workshop and to convert the milling machine. All of La Palme's parts and plans are stowed and LRe's restored. As soon as all frames are installed, there are also new pictures, I only have 7 pieces left, hooray.
