Thanks Jim.Sergey is a member of our forum. Please PM (Personal message) him @bibigon He will be prompt to respond and happy to help yopu.
Will be praying for a successful outcome to your eye surgery...
Thanks Jim. I am looking forward to getting my vision back to 20/20 then I can really see and appreciate all the mistakes I have made in my build so farWishing you good luck with your eye surgery, and a fast recovery.
Cataract surgery? Easy peasy! You'll be at or near 20/20 and colors wil much more noticeable. I don't think CA will affect your IOL's but you should ask the opthalmologist. (I had the procedure 6 years ago).Very little has been accomplished since I finished planking the hull. I have now filled and sanded the hull as necessary. I’m going to use a diluted PVA glue or a scenic cement to seal the wood. Then after testing on scrap basswood I’ll see if it’s suitable, longterm, for the copper plate tape glue.
However, everything is almost at a standstill now as I prepare for eye surgery later this month. I know recovery will be a few weeks and I suspect I will be given my orders with regard to ship modelling. The fine dust from sanding may be a problem as may other contaminants. In particular I wonder if CA glue fumes will adversely affect the “new” intraocular lenses over time.
So lots of reading in the next few weeks. I have a stockpile of books sitting on bookshelves and lots of time to lurk around this SOS site reading all your great posts. I wonder if it will get me out of doing the dishes, vacuuming and laundry?![]()
Hi Phil, yes cataract and astigmatism correction plus lots of floaters. I really appreciate your response, it gives me a little more confidence in the outcome. Sometimes thinking about the unknown is worse than the process. I’ll definitely ask about the CA because even with eye protection afterwards there’s still the off-gassing in and around the model.Cataract surgery? Easy peasy! You'll be at or near 20/20 and colors wil much more noticeable. I don't think CA will affect your IOL's but you should ask the opthalmologist. (I had the procedure 6 years ago).
Thanks Paul.Brilliant Roger! Problem solving lies at the heart of our work. And all this without a power tool!
Hello, Roger. I will pretend to be your photographer and will say, you need to use a scraper or shaper as we call them. You made a very good molding, but...you are using the cutting edge of the gouge against the metal ruler, this will dull the tool. The second observation, it is kinda dangerous for your hold hand. One slip...and...God forbid!Thanks Paul.
What I needed was my photographer to look at the mouldings and say "you need a power tool for that". No such luck.
Hi Jim,Hello, Roger. I will pretend to be your photographer and will say, you need to use a scraper or shaper as we call them. You made a very good molding, but...you are using the cutting edge of the gouge against the metal ruler, this will dull the tool. The second observation, it is kinda dangerous for your hold hand. One slip...and...God forbid!
You can buy those scrapers online but, you can make them by yourself, pretty much all kinds of shapes, out from an old\dull sheetrock cutter blades. You can do it with diamond-coated needle files or cutting disks in a rotary tool.
The power tool might not be a good choice for such a small molding, IMHO
So....are you going to buy pre-made lumber or buy a board to mill by yourself?I am going to replace some of the basswood (crumblewood) on my Syren build. I’d like to use a better quality wood.
I am considering either boxwood or swiss pear for the decking. I also want to replace the inner bulwark planking. However, I feel it a waste to use the boxwood or pear on the bulwarks because they will be painted that reddish colour. So I am thinking of yellow cedar for that area. The supplied basswood just does not paint well.
The cedar comes in a lot cheaper but I have never used it before in model making. I will be using Vallejo acrylics for the paintwork. I might be wrong but I believe yellow cedar is a little oily? Does anyone know if acrylic paint “takes” well on yellow cedar?
Thanks for any help, comments and advice.
